Engine block heater cord?? - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 12-20-2010, 05:12 PM Thread Starter
Duramax Deputy's Avatar
Question Engine block heater cord??
Ok, so I have to raise my hood everytime I want to plug my truck in. Can I run a heavy duty extension cord from the factory cord and run it down by the tow hooks so I can just plug it in there instead of opening my hood everytime??
2007.5 GMC Sierra 4x4 crew cab LTZ 6.6 LMM Duramax. Afe cold air intake stage 2, MBRP 5 inch exhaust. Edge evoluton CS. DPF delete straight pipe.
Duramax Deputy is offline
post #2 of 10 (permalink) Old 12-20-2010, 05:14 PM
saw what you did there
theunderlord's Avatar
just take the cord from the truck and run it through the grille..
http://www.duramaxforum.com/forum/ho...faq-burrr.html
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #3 of 10 (permalink) Old 12-20-2010, 05:15 PM
mijdirtyjeep's Avatar
You can just undo it from all the other wires and unwrap it all the way back to were it connects to the engine block, that is what I did to get mine mounted at the tow hook.
Jim
mijdirtyjeep is offline
post #4 of 10 (permalink) Old 12-20-2010, 05:21 PM
Oxcart's Avatar
The cord is plenty long enough to stick out 3' from the front if you wanted. You need to cut back some of the tape to the cord as its in the front anyway and taped back up the wire harness toward the pass side battery...
Mike
2008 LMM
2002 LB7
Running MMLMM "Grim Reaper" tunes
Oxcart is offline
post #5 of 10 (permalink) Old 12-20-2010, 05:29 PM
how cold does it have to get befor you plug your trucks in?
6 inch fabtech suspension lift
Amp research electric running boards
35x12 pro comp extreme all terrains
17 inch moto metal rims
bushwacker fender flairs
tinted windows and tail lights
AFE cold air intake
5 inch turbo back MBRP exhaust
PCV re-rout and blocked resignator
shaved antenna
tunning...unknown
liftedlbz is offline
post #6 of 10 (permalink) Old 12-20-2010, 05:34 PM
it's in the link, honest!
post #7 of 10 (permalink) Old 12-20-2010, 05:38 PM
Durallymax's Avatar
As mike said, that cord will drag on the ground if you want it to. Just pull it out of the loom as far as you want, then route it wherever you want it to be at.
Durallymax is offline
post #8 of 10 (permalink) Old 12-20-2010, 05:45 PM Thread Starter
Ok, I guess I need to look under the hood better. Just felt that there was some resistance when I pulled on it so I quit. Thanks for the help!!
post #9 of 10 (permalink) Old 12-20-2010, 05:50 PM
Durallymax's Avatar
There ios resistance. Follow the passenger side battery cables and you will find the block heater cord. Then just pull it out of the loom as much as you want.
post #10 of 10 (permalink) Old 12-23-2010, 11:43 AM
ZX10Aviator's Avatar
I have mine in the pass wheel well at the top of the shock, easy to reach.
-SOLD- '05 Sierra Duramax
* Just did HeadGaskets 10-30-2010 * Click for link
-Edge Juice with attidue, AFE Turbo inlet, Rerouted PCV, EGR Blocked and Fingersticked from KennedyDiesel, Grade C HeadGaskets, ARP Head Studs, looking for more mod advice, for longevity and better MPG
ZX10Aviator is offline
