Need help changing the starter! - Chevy and GMC Duramax Diesel Forum
post #1 of 30 (permalink) Old 01-01-2011, 01:44 PM Thread Starter
Spooner's Avatar
Anyone know of a good write up with pictures on how to do this? I honestly don't see how there is enough room for this thing to come out! Pulled the fender liner out and I can see it in there but I don't see how it will come out from the side or the bottom. Can you wait to undo the main cable for when you drop it out? I don't see how to get a wrench or socket on it the way it sits in there. This whole thing is showing me why I much prefer working on motorcycles to vehicles haha!
2005 CCSB LT3
S&B Intake, AFE Bladerunner Intake Tube, 5" exhaust, EFI Live tuned, Pyro, Boost, Aeroforce Interceptor, 18" Diamo rims with Terra Grapplers, HID's, Rock Crusher diff cover.
2006 Yamaha YZ 250f
2008 Honda CBR 1000RR Road Race
2009 Kawasaki ZX-6R Road Race
Spooner is offline
post #2 of 30 (permalink) Old 01-01-2011, 01:53 PM Thread Starter
Spooner's Avatar
One thing I keep reading is to loosen the down pipe for more room-I loosened the clamp but I don't see how anything will move unless I remove the rest of the exhaust system..I must be missing something here.
2005 CCSB LT3
2006 Yamaha YZ 250f
Spooner is offline
post #3 of 30 (permalink) Old 01-01-2011, 02:40 PM
mean91eagle's Avatar
this is out of a helms manual
1) Disconnect both Negative battery cables.
2) Remove the front passenger wheel/tire - jack it up first.
(I think all you need to do is jack up at the frame in front - this will lower the tire mostly out of the way)
3) Remove the wheel inner liner - be careful of the those two-part GM connectors.
4) Remove the batter positive connector and solinoid wires.
(You might want to spray some WD-40 or similar to loosen up the rusty ones)
5) Remove the starter motor bolts.
(Two bolts - they go into a triangularish plate that holds both the motor and solenoid) (You will also be able to see the flywheel through the hole where the gear mates).
Reverse procedure to reinstall
TORQUE NUMBERS - NOTE foot-pounds(lb-ft) and inch-pounds (lb-in)
78 N-m (58lb-ft) STARTER BOLTS
3.4 N-m (30lb-in) SOLENOID NUT
9 N-m (80lb-in) BATTERY POSITIVE CABLE
hope it helps. Its from a 2001 but Im sure its similar
2006 Silverado 2500HD LBZ, 3" downpipe (goodbye little ratchet) , 4" MBRP exhaust, Edge Insight CTS, DSP5 EFI live, AFE stage 2 intake, PPE Race Valve, PPE ported fuel rail fitting, PPE cp3 inlet fitting/line, 6" CST lift, 5/8" tranny lines, PCV reroute/resonator plug/EGR block, 35" Mickey Thompson ATZ, 20" ION wheels - SOLD
2005 Sierra 2500HD LLY - 5" FloPro exhaust, AFE bladerunner turbo mouthpiece, EGR delete, PCV reroute
mean91eagle is offline
post #4 of 30 (permalink) Old 01-01-2011, 02:42 PM Thread Starter
Spooner's Avatar
Yeah I've seen that but 'remove bolts' isn't descriptive enough haha!
2005 CCSB LT3
2006 Yamaha YZ 250f
Spooner is offline
post #5 of 30 (permalink) Old 01-01-2011, 04:54 PM
how is it not? its as simple as that... remove bolts.
haha ya i hear ya It was like the instructions to remove my factory downpipe.
To answer your one question u can wait to remove the starter before you remove the cable. Not sure how much slack it has so it might not drop much. Ive never done it before on the d-max but usually its a pretty easy job. Like everything is on any vehicle other than a GM
post #6 of 30 (permalink) Old 01-01-2011, 07:13 PM
can we see a picture on what your looking at for why it wouldn't come out
cowboydiesel is offline
post #7 of 30 (permalink) Old 01-01-2011, 07:21 PM
saw what you did there
theunderlord's Avatar
The bolts are ON there, eat your wheaties!
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #8 of 30 (permalink) Old 01-01-2011, 08:18 PM Thread Starter
Spooner's Avatar
Here is a picture from the side.
2005 CCSB LT3
2006 Yamaha YZ 250f
Spooner is offline
post #9 of 30 (permalink) Old 01-01-2011, 08:18 PM
DuraMac's Avatar
Send a message via AIM to DuraMac Send a message via Yahoo to DuraMac Send a message via Skype™ to DuraMac
Think a thin walled socket and lots of universal joints are needed last I looked and at the end a HUGE T-Bar! :-)
DMax BLACK '05 LS CC LB @ 100K miles, factory 2" lift, HID's
Banks Economind, IQ, Intake, SpeedBrake, Boost Tube, Monster Exhaust
Other AFE MP, Amsoil & Bypass, Ameriguard spray-in liner, Leer Cap, Bed Rack, Bug Guard, Inverter.
Crap Iron Cross Automotive Nerf Bars - NOT RECOMMENDED!!
Helpful Helm GM Service Manuals - like... 9000 pages!!
Rescue VHF Radio, Jotto Desk Laptop command center, Rescue Gear, Lotsa Flashy LED's, Shinny Decals
Haulin B&W Turn Over Ball & Companion, Firestone Ride-Rite Air Lift Bags, '14 Heartland Warrior Toy Hauler, (12000lb dry), Kayaks, Harley
DuraMac is offline
post #10 of 30 (permalink) Old 01-02-2011, 03:27 PM Thread Starter
Spooner's Avatar
My 'pain in the ass' meter is starting to peg out. Any idea how much a shop would charge to swap it?
2005 CCSB LT3
2006 Yamaha YZ 250f
Spooner is offline
