Old 07-19-2008, 10:24 AM   eBay Motors   #1 (permalink)
smokin6.6
Points: 162, Level: 3
Points: 162, Level: 3 Points: 162, Level: 3 Points: 162, Level: 3
Activity: 0%
smokin6.6's Avatar
285's or 265's
wondering what size i should go with. id like to keep from lifting the truck if possible, more of a sleeper truck. but id still like to have the wheel wells filled out a little more. they will be mounted on 17 x 9 dc-1 wheels. what do you think the 265's will look like. will the 285's have clearance issues with the stock suspension. thanks for any input.
smokin6.6 is offline   Reply With Quote
Old 07-19-2008, 10:54 AM   eBay Motors   #2 (permalink)
BigRedChevy
Catch Me If You Can!
Points: 8,118, Level: 38
Points: 8,118, Level: 38 Points: 8,118, Level: 38 Points: 8,118, Level: 38
Activity: 100%
BigRedChevy's Avatar
With the 285s you will probably have to crank the t-bars a little and trim the front valance. The 265s will fit with out any modifications.
KYLE
Old 07-19-2008, 03:16 PM   eBay Motors   #3 (permalink)
dieselfan
Points: 635, Level: 9
Points: 635, Level: 9 Points: 635, Level: 9 Points: 635, Level: 9
Activity: 0%
dieselfan's Avatar
Go with the 285's better look and ride! might cut mileage a little but hell fuel is only $4.65 a gallon!
2006 silverado CC silver birch kmc hoss 20's 305/50/20 nitto's s&b intake and amsoil oil. ppe economy tuner more to come...
dieselfan is offline   Reply With Quote
Old 07-19-2008, 03:21 PM   eBay Motors   #4 (permalink)
Landscapeman
Save Water, Drink Beer
Points: 3,358, Level: 24
Points: 3,358, Level: 24 Points: 3,358, Level: 24 Points: 3,358, Level: 24
Activity: 4%
Activity: 4% Activity: 4% Activity: 4%
Landscapeman's Avatar
I have had 285's on my truck and it did cut some millage. I now have 265's and they still look sharp and give better millage. Good Luck
2006 GMC 2500HD LBZ Crew Cab 4x4, Silverline Turbo Back Dual Exhaust, PPE Hot Programmer, Egr Block Plate, PPE Air Box Mod, 2in. Plug, SES Light
Full Bore Exhaust Manifold compliments of BD Diesel.
Landscapeman is offline   Reply With Quote
Old 07-19-2008, 03:54 PM   eBay Motors   #5 (permalink)
deereboy80
Points: 355, Level: 6
Points: 355, Level: 6 Points: 355, Level: 6 Points: 355, Level: 6
Activity: 3%
Activity: 3% Activity: 3% Activity: 3%
deereboy80's Avatar
I'm running 285's and will never go back. You will have to trim the front valance a bit, but shouldn't have to crank the t-bars at all. It will mess up your speedometer a bit, mine did about 4 mph at 65. This will account for your fuel mileage drop. Mine didn't drop more than about .75 mpg adjusted.
'04 GMC LB7 Crewcab Shortbed
AFE Stage 2 Intake
Diamond Eye 4" Single Exhaust
Edge Juice w/Attitude
Air Lift 5,000Lb bags with Ride Control
B&W Turnover Ball
RollBAK roll tarp
deereboy80 is offline   Reply With Quote
Old 07-19-2008, 03:57 PM   eBay Motors   #6 (permalink)
deereboy80
Activity: 3%
deereboy80's Avatar
Make sure you keep the weight rating that you need. I needed load range E and the only one's available in 285's were BFG All Terrain T/A's.
AFE Stage 2 Intake
B&W Turnover Ball
RollBAK roll tarp
Old 07-19-2008, 04:57 PM   eBay Motors   #7 (permalink)
daddysLBZ
BRAIN SURGEON !!!haha
Points: 4,816, Level: 29
Points: 4,816, Level: 29 Points: 4,816, Level: 29 Points: 4,816, Level: 29
Activity: 83%
Activity: 83% Activity: 83% Activity: 83%
daddysLBZ's Avatar
I put the 285/75/16's on mine no mods..But with the 17 inch you may crank the torsion bars a bit,then if you like you can trim the air dam at bottom of front bumper,I am goin back to 265's just to see where I can get my mileage.I can squeeze 22mpg at 70 mph[unloaded of course]with the 285's.So I am thinking that I could use the 1-2 mpg I lost when puttin the 285's..Good luck!!!
There she is<<
2006 GMC 2500HD4x4 sb cc LBZ!!!52k
MODS/Full straight pipe,res mod,SC Fpaq tuner,285/75/16's
Additional gray Berber carpet on floorboards/courtesy of a customer whose home we just built!!!!FREE
2002 GMC 1500 2wd x-cab-sb 5.3l.
1987 89,000k 305H.O. 700-r4[pearl white/red striped]
1978 Malibu[2dr]350c.i./350hp TH-350 trans/jus a lil quick!!!
Old 07-19-2008, 10:46 PM   eBay Motors   #8 (permalink)
Tow Master
Super Man Moderator
Points: 10,388, Level: 43
Points: 10,388, Level: 43 Points: 10,388, Level: 43 Points: 10,388, Level: 43
Activity: 100%
Tow Master's Avatar
I had 285's on my truck and went to 265's I missed the look and went back to 285's. The 285's dont get as good mileage but they look better. Most people get 8 wide wheels so your 9 might make the tire a little shorter that it would on a 8. You might have to crank the torsion bars a little but not where it will hurt anything. The only think is if you adjust the torsion bars you gotta get a alignment when your done.
Jason
2006 Silverado Shortbed Crew Cab LBZ
Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights
4 Kicker 10in Subs & Punch 250amp in 2 custom boxs. Autometer Ultralite II Pyro & EGT gauges with pillar pod
MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2
Lost Kitty Reward if found!!
1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake
Tow Master is online now   Reply With Quote
Old 07-19-2008, 10:52 PM   eBay Motors   #9 (permalink)
TheHoov
Points: 2,890, Level: 22
Points: 2,890, Level: 22 Points: 2,890, Level: 22 Points: 2,890, Level: 22
Activity: 1%
TheHoov's Avatar
I have 285 and love the look of them. I would love to get a little bigger wheel though.
2002 Chevy LB7 Crew Cab
Thank you Duramax Forums
TheHoov is offline   Reply With Quote
Old 07-20-2008, 09:19 AM   eBay Motors   #10 (permalink)
Johnasara
Points: 5,252, Level: 30
Points: 5,252, Level: 30 Points: 5,252, Level: 30 Points: 5,252, Level: 30
Activity: 22%
Activity: 22% Activity: 22% Activity: 22%
Johnasara's Avatar
If you are running a different wheel with the tire you will have to crank on the torsion bars. When I had 285s on the stock wheel I did not have to adjust anything. I put the same tires on the aftermarket wheels and I had to crank the bars up three turns. I will eventually put a leveling kit on but for now I just have the bars turned up.
06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR
WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST. QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE
