Old 07-21-2008, 03:36 PM   eBay Motors   #1 (permalink)
pdog
Points: 4, Level: 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Activity: 0%
limp mode
have a 05 duramax ,with edge chip whenever under a load or towing goes into limp mode , with or without chip in the truck . had it to the dealer 6 times they keep bringing up fuel preasure regulator code and egr say they have replaced the preasure regulator and preasure regulator valve ? FRUSTRATED took it to diesle mechanic said same thing and want 2 grand to fix it , hate to spend the money when its still under warentee 2 dealers and after they do there thing , hook up 14 foot motorcycle trailer and it goes into limp mode like clock work check engine light has never come on ! any thoughts ?
pdog is offline   Reply With Quote
Old 07-21-2008, 04:04 PM   eBay Motors   #2 (permalink)
GmcLbz
Points: 1,057, Level: 12
Points: 1,057, Level: 12 Points: 1,057, Level: 12 Points: 1,057, Level: 12
Activity: 10%
Activity: 10% Activity: 10% Activity: 10%
GmcLbz's Avatar
So it's an Engine limp? Have you change fuel filter?
07' GMC CC/SB Diamond Eye direct downpipe, 4" Mbrp DP back, Airaid CAI w/Amsoil dry filter and prefilter, fingered and blocked, Transgo Jr, UDP tie rod sleeves, Cognito braces, H2's w/285 BFG's, Airdog 150, EFI Live, Autometer phantom boost and pyro
GmcLbz is offline   Reply With Quote
Old 07-21-2008, 09:50 PM   eBay Motors   #3 (permalink)
BigRedChevy
Duramax Forum Moderator
Points: 6,212, Level: 33
Points: 6,212, Level: 33 Points: 6,212, Level: 33 Points: 6,212, Level: 33
Activity: 100%
BigRedChevy's Avatar
X2 on the fuel filter. Also you may need to shim the fuel pressure relief valve, very cheap mod. Also what level was you running on the edge? If your running one of the bigger tunes you may need a lift pump.
KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan
Old 07-21-2008, 10:25 PM   eBay Motors   #4 (permalink)
duramaxin14
Points: 2,259, Level: 19
Points: 2,259, Level: 19 Points: 2,259, Level: 19 Points: 2,259, Level: 19
Activity: 1%
duramaxin14's Avatar
Unstead of shimming it pay the extra couple bucks and put a race vavle in it so much better.
Snow flake 2004.5 D/A Efi live, PPE lift pump, 35inch mudders and a florida stack
13.20@115 mph
duramaxin14 is offline   Reply With Quote
Old 07-21-2008, 10:40 PM   eBay Motors   #5 (permalink)
BigRedChevy
Activity: 100%
The only bad part about the race valve is it won't let any fuel back to the tank. If for some reason you do build too much pressure it has no place to go.
KYLE
Old 07-21-2008, 10:47 PM   eBay Motors   #6 (permalink)
duramaxin14
Activity: 1%
Correct but ive never had a problem with building to much pressure i cant build enough. Fuel will still get back to the tank bye the return line.
Its something like this. if u have a straw and hold your finger over 1 end of the straw and blow into it. When air gets to the end of the straw it will go no where. It will mantain that pressure until it can be realeased. It will not build more pressure because there will always be a steady flow of fuel. And what fuel is not getting used before it gets to the rail will be sent back threw the return line. Its like taking a quick detour i guess. I know i didnt explain to well i will sleep on this and think of a better way to say this in the A.M Or maybe someone will cacth my drift and fill in for me
13.20@115 mph
Old 07-22-2008, 08:35 AM   eBay Motors   #7 (permalink)
IdahoRob
Points: 3,774, Level: 25
Points: 3,774, Level: 25 Points: 3,774, Level: 25 Points: 3,774, Level: 25
Activity: 21%
Activity: 21% Activity: 21% Activity: 21%
IdahoRob's Avatar
What codes are you throwing? Need to know what kind of limp to help you out.
Problem with a race valve is not when commanding rail pressure, the problem is when you are commanding 26,000psi under WOT then you have to lift the throttle. The rail pressure spikes to very high levels, 30,000+. The FPRV will open at this time relieving the pressure, the race valve will not.
With a weak FPRV, the engine limp occurs after WOT when the throttle is released. A shim will stop this problem, but still allow pressure relief at insane levels of rail pressure.
2007 LBZ CCSB 4x4,EFI(tuned by me), ATP Transmission
11.89 on #2 http://s173.photobucket.com/albums/w...Coddens3mb.flv
PPE, EFI Live, Suncoast Dealer
Adrenaline Truck Performance 208.484.3670
IdahoRob is offline   Reply With Quote
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
