Light grey smoke - Chevy and GMC Duramax Diesel Forum
post #1 of 44 (permalink) Old 01-22-2011, 11:58 AM Thread Starter
CUSTOMBUILT's Avatar
Light grey smoke
Hi Everyone, I'm getting lots of light grey smoke from my exhaust. What should I do to solve this problem? Any help will be appreciated. Thanks
2005 SILVERADO 3500 DUALLY 4X4.
BANKS POWER PACKAGE. MOUTHPIECE. EGR BLOCKED. PCV REROUTE. STAGE 3 TRANS BY INGLEWOOD TRANSMISSIONS. UPGRADED HG.
AVATAR: MY TOYS
CUSTOMBUILT is offline
post #2 of 44 (permalink) Old 01-22-2011, 10:25 PM Thread Starter
Anybody?
AVATAR: MY TOYS
post #3 of 44 (permalink) Old 01-22-2011, 10:40 PM
bigblackdmaxx's Avatar
hmm ive heard that grey smoke means injectors are going out... but i wouldnt take my word on that!!
Goes by Taylor
2012 Range Rover Autobiography
Sadly Sold :2005 Lly Black 4wd cc/sb
6 inch Rancho lift kit with 35's
4 inch strait pipe, Egr delete, MA High Performance Duramax Motor Mounts :rockin AFE stage 2 cold air intake, Lbz mouthpeace, PPE Exhaust Manifolds & Up Pipes, 4.56 gears
EFI by IdahoRob With a little extra fuel
You may all go to hell and I will go to Texas. –Davy Crockett
bigblackdmaxx is offline
post #4 of 44 (permalink) Old 01-23-2011, 12:48 AM Thread Starter
Thanks bigblackdmaxx. I had a feeling it would be an injector issue. Does anyone know of someone in the Los Angeles area that can check my injector rates? The help would be appreciated. I also did the ice pick trick today and checked my harness it didn't help. I'm still smoking like a CHOO-CHOO!
AVATAR: MY TOYS
post #5 of 44 (permalink) Old 01-23-2011, 06:18 PM Thread Starter
Anyone?
AVATAR: MY TOYS
post #6 of 44 (permalink) Old 01-23-2011, 06:48 PM
sounds like injectors, too much fuel or not enough air would make it black as night, like collant entering the cylinder would make it grey
2004 Chevrolet 2500HD regular cab long bed LB7 Duramax
EFI Live Tuned By Day's Diesel
Glowshift Pyro & Boost Gauges
MBRP 4" Exhaust
Rhino Line bedliner
B&W Goose Neck Hitch
Windows Tinted 15%
Recon Tailgate Light Bar
Powdercoated Stock Rims
Goodyear Silent Armors 285/75R16
Next: Fass fuel system, Stage 4 trans kit,
epro is offline
post #7 of 44 (permalink) Old 01-23-2011, 06:51 PM
Slave to the Interwebs
Johnasara's Avatar
Is it doing it at Idle??
Johnasara is offline
post #8 of 44 (permalink) Old 01-23-2011, 07:38 PM Thread Starter
Not smoking at all when at idle, but when i put it in drive and push the accelerator 10% it starts smoking and doesn't stop unless i release the pedal.
AVATAR: MY TOYS
post #9 of 44 (permalink) Old 01-23-2011, 07:42 PM
Johnasara's Avatar
Disconnect the banks and see if it changes.
post #10 of 44 (permalink) Old 01-23-2011, 07:43 PM
got the go fast itch
iranaround's Avatar
Send a message via AIM to iranaround
take a video of it
Greg 05 LLY GMC Duramax Crew Cab SLT
Two inch lift 285 Nitto T.G. on Mojave's Full Egr delete Autometers AFE mouth piece AEM Brute Force
PPE Duramax Race Fuel Valve MBRP Turbo Back with downpipe 4" to 7 "single stack EFI Live with dsp5 tuning by Rob TCM tuning by Rob
Big Dipper stage IV Transgo shift kit Precision ML converter Raptor 150 lift pump DDP 75hp nozzles ARP headstuds
iranaround is offline
