Fixes for C0035 codes? - Chevy and GMC Duramax Diesel Forum
Old 03-07-2011, 11:37 AM   eBay Motors  #1 (permalink)
caps76's Avatar
My truck threw a c0035 code, I looked up the code and from what I found it is a problem left front wheel sensor. Anyone ever get this code and what did you do to fix it? just change out the sensor? I know nothing about what would cause the code of if something else is wrong and the sensor is just letting me know that? Is this something minor or major? Should I be worried? Any help would be great, Thanks
2004 LLY CC 4X4 LT
First time diesel owner
www.centralfloridaduramax.com
caps76 is offline   Reply With Quote
Old 03-08-2011, 05:27 AM   eBay Motors  #2 (permalink)
caps76's Avatar
bump
2004 LLY CC 4X4 LT
Old 03-08-2011, 10:11 AM   eBay Motors  #3 (permalink)
caps76's Avatar
bump
2004 LLY CC 4X4 LT
Old 03-08-2011, 10:18 AM   eBay Motors  #4 (permalink)
viejajefita's Avatar
I had to change the entire hub/bearing assy that comes with new sensor. Around $300 per side. Both my trucks went at 70+k. Kind of ironic i think. You can pull the rotor and try and clean it but usually just bad bearings.
'06 2500 HD cc 4x4 Allison trans
Edge Evo Race level 2
265/75-16 BFG's
LBZ w/200k+ seen as high as 21mpg and as low as 8mpg
PPE free airbox mod from DIY sticky Firestone bags married to Ride Rite comp and gauge
Clinton lied. A man might forget where he parks or where he lives, but he never forgets oral sex, no matter how bad it is.
Barbara Bush
viejajefita is offline   Reply With Quote
