| Duramax Lifetime Supporter Join Date: Apr 2010 Location: central florida
| oil level sensor location? where is the oil level sensor located on the lly motor. my DIC keeps telling le to check engine oil level but i know for a fact that it is at perfect level on the dipstick. so i assume this sensor has gone bad. unless there is ather issues that throw this off. thanks |
| The level sensor in attached to the oil pan, close to the filter-- dirver's side. Sure about the level-?
| would you say that it has gone bad if i keep getting this message? And yes im positive about the level of oil. unless my dipstick is playing tricks on me. |
| Junior Member Join Date: Feb 2011 Location: Burton, WI
| Is it hard to replace it mines shot wire are broke?
__________________ 04 lb7 Suncoast stage 5 Edge cts Efi live from empire diesel Traction bars Lift pump Boost valve Hids all around Arp head studs Worked cp3 |
| Duramax Lifetime Supporter Join Date: Mar 2009 Location: Ontario,Canada
| You will have to drain your oil pull that cross plate piece off (4 bolts) and drop the bottom oil pan, it's held in by a clip on the inside of the oil pan, it's not a big deal
__________________ 05 Silverado Crew Short Bed LLY,6" superlift, 22" dubs 35" nitto Terra Grapplers AT,AFE Stage 2 W/pro guard 7, ARP Head studs Lbz mouth piece,fuel Rail shimmed,5" Mbrp turbo back cat delete with 6" tip Diamond eye down pipe Autometer phantom 2 gauges, trans go shift kit Mag hytec deep trans pan, BD manifold, egr blocked no fingerstick Pcv reroute,PPE standard, kennedy diesel boost stick 52 Gallon Titan tank, AD-165 Amsoil throughout 2003 GMC Sierra LB7 Reg Cab with ZF6, 636000km on the clock, engine rebulit by me, Leveled,Bilsteins |
