Why delete the EGR? - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 05-17-2011, 12:27 PM Thread Starter
Why delete the EGR?
I keep reading forums and post about deleting the EGR but I cannot find a reason why. Can anyone help me on this? I just bought my first Duramax and am trying to get a good understanding. Also if I delete it do I need to have EFI reprogrammed to block a code?
garrecr is offline
post #2 of 9 (permalink) Old 05-17-2011, 12:30 PM
I STILL DGAF
Duraskank's Avatar
Good for the motor and you can gain 30 - 60 rwhp depending on tuning. That's the general concensus anyway.
GW: 2005 CHEVROLET LT CCSB LLY 4WD|SOLD|SkankLilly
2006 GMC SLT ECSB LBZ 4WD -SOLD skankmobile2dot0 Pics
2007 CHEVROLET LS CCSB LBZ 4WD|June ROTM 2011 - SOLD|Dmax Pics
07.5 CHEVROLET LT2 CCSB LMM 4WD|SOLD|LMM 'build' thread|LMM pics
2011 GMC RCLB LML 4WD @duraskank
Duraskank is offline
post #3 of 9 (permalink) Old 05-17-2011, 12:34 PM
I believe the reason people delete it is because:
A: it is just another emmissions piece they dont wanna deal with
B: it recirculates old exhaust gas into the engine-which most dont want.
C: its one less failure you have to be concerned about. I know fords have problems with EGR coolers....not cure about GM.
There may be other reasons.....might gain some performance. Oh and yes, ifs the EGR is gone....you have to have a way to turn it off, otherwise you will have a check engine light on cause ECM is looking for egr and there is none!
VtecGSR95 is offline
post #4 of 9 (permalink) Old 05-17-2011, 12:34 PM Thread Starter
So if I do delete I need to re-tune EFI to notice the change? Can EFI block that code?
garrecr is offline
post #5 of 9 (permalink) Old 05-17-2011, 12:37 PM
I STILL DGAF
Duraskank's Avatar
A: it is just another emmissions piece they dont wanna deal with Frees up some room too!
B: it recirculates old exhaust gas into the engine-which most dont want. Which is why it's good for the motor.
C: its one less failure you have to be concerned about. I know fords have problems with EGR coolers....not cure about GM.No big issues with failures I don't think.
You most definitely will gain hp. People have dyno'd before and after to prove it.
You just need to disable it, don't think you need to do any special tuning just because you delete it. EFI Live will do that for sure.
post #6 of 9 (permalink) Old 05-17-2011, 01:30 PM
Phild101's Avatar
Lets pretend I didn't type anything here. Sorry to have taken up the space.
Later
Phil
Silver Birtch,08 LMM, CC, Air Hawk Stainless Mud Flaps, Iron Cross boards, Kenwood/Hertz/Audison, BF Xenon 8000K HID's, BMF M80's, Ready Lift, tonneau cover, Airaid intake, Firestone air bags, Egde CTS guage, EFI live DSP5 and MBRP 4"
http://duramaxtuner.com
Phild101 is offline
post #7 of 9 (permalink) Old 05-17-2011, 01:43 PM
storminyoung1's Avatar
The main benefit is to reduce soot getting back into the motor thru the exhaust. Especially if your running a tuner of some sort, the more black smoke out the exhaust, the more the EGR will pump it into your oil. It mostly helps with oil change intervals, sensor life, & overall engine longevity. I dont know anything about adding hp. I did it went I put my exhaust and CAI on, and dont believe I picked up any extra hp. with that mod. Also, if you go the EFILive route with tuning, you or your tuner can disable that function so it doesnt throw any codes.
'05 GMC SB Ext.Cab
EFI W/DSP2 from Nick
AFE MP & S&B CAI
EGR delete & PCV rerouted
5" Exh. straight pipe
All-on mod.
storminyoung1 is offline
post #8 of 9 (permalink) Old 05-19-2011, 09:41 PM
diesels make power by compressing via turbo, cold fresh air into the engine, hot exhaust gases cooled to engine temps (around 200 degrees) don't do a diesel much good.
Roll Tide is offline
post #9 of 9 (permalink) Old 06-14-2011, 11:31 PM
How would deleting the egr affect the engine in cold weather? During the winter we can hit -40. Will not having an egr cause problems with cold weather drivability or starting??
2016 LTZ, Stock (for now)
OLD - 2005 GMC CC/SB - LLY - aFe 4" Turbo Back - aFe MP - Engineer837 Secondary Cooling System - Earl's Tranny Cooler - ISSPro Boost & Pyro in a Triple pod with Insight CS controlling Tunes by IdahoRob - PCV re-route, EGR blocker plate, Clarion NX500 head unit - Hi, Lo, & Fog HID's wired for All on. LED's Everywhere!
2015 Coachman Chaparral X-lite 28bhs
2006 Yamaha Raptor 700
Cdn_Blair is offline
