2004 duramax problems - Chevy and GMC Duramax Diesel Forum
post #1 of 2 (permalink) Old 06-01-2011, 06:03 AM Thread Starter
I have a 2004 Gmc 2500 Duramx with 238000kms. The truck will have a faint knocking noise sometimes and then it will loose all its power and the engine light will come on. I was told when it looses all its power it goes into "limp mode". I have had it looked at but the computer shows no codes for the problem. If i shut the truck off and turn it back on it is normally good again for a day or so. Does anyone know what could be causing this?
Brando55 is offline
post #2 of 2 (permalink) Old 06-01-2011, 09:34 PM
ramonday's Avatar
If you have the LLY, check out the "icepick" fix. Just google search it. To see if you have the LLY, check the 8th digit in the VIN and see if it's 2. If so, do the icepick.
2004.5 GMC Sierra SLT EC 2500HD 4x4 LLY w/LBZ MP, PCV reroute, EGR blocked, 4" exhaust, PacBrake TR sleeves, DSP5 & EFI-Live w/Idaho Rob tunes
ramonday is offline
