EGR delete & PCV reroute COMPLETE - Chevy and GMC Duramax Diesel Forum
post #1 of 16 (permalink) Old 07-04-2011, 07:22 PM Thread Starter
glock-hater's Avatar
OK, add me to the list. Just finished mine. What a PITA. I did the Sinister kit that removes the whole cooler and egr motor. The back bolts were a pain as Im sure most of you know.
Now then, some questions: Is it just me or does my truck sound different now? Will this boost my power any and will I see a return in fuel economy?
Im just wondering why I and why so many of you do it?
05' LLY, 2500HD 4x4 EC LB 305 Mickey Thompson MTZ's AFE mouthpiece, 5" MBRP no muff, no cat + a sexy 6" tip
Superchips 80 horse tune. Sinister EGR delete, PCV reroute.
glock-hater is offline
post #2 of 16 (permalink) Old 07-04-2011, 07:57 PM
Skierbum's Avatar
I didn't have too much trouble with mine. I did get a different sound though. I keep blowing out my intake manifold tube and it does hiss and doesnt make as much boost, but i have hit 25+ psi with the delete and my edge evo on level three i get about 22-25 depending on the weight of my right foot it also makes for a cooler intake charge and no soot running through the engine= longer engine life
05 lly crewcab short flatbed 4x4 stock except for a 5in straight pipe, edge evo race, and a sinister egr delete.
06 ext cab 2wd drw 462,xxx, New motor with 5k, 3.5 inch downpipe to 4inch straight pipe, 19.5s, Custom towbody, Efi live from www.powerlabsdiesel.com, built tranny, egr delete, airbags, and Edge insight.
Thanks to Gary at diesel pros in Bozeman, MT
Cam at Adrenaline Performance in Shelley, ID
and the guys at powerlabs for tuning.
http://www.Alligatorperformance.com/
Skierbum is offline
post #3 of 16 (permalink) Old 07-04-2011, 08:07 PM Thread Starter
What do you mean when you say "blowing out your intake tube"? You are talking about the tube that runs from your air box to your mouthpiece correct?
Sent from my DROID2 GLOBAL using AutoGuide App
post #4 of 16 (permalink) Old 07-04-2011, 08:13 PM
Skierbum's Avatar
its the part that disappears down into the engine, You unbolt the intake manifold to bolt on the blocker plates (mine were anodized blue) and its the aluminum piece with a stud and a hole. Its post turbo because it has to hold boost. Mine smoked really bad and it just pushes into the intake manifold that feeds the heads and is only held in by 2 o-rings.
Hopefully thats a good enough explanation if you need me too i can post a picture.
Skierbum is offline
post #5 of 16 (permalink) Old 07-04-2011, 08:18 PM Thread Starter
Nah, I'm with ya now. Well that really sux. What are you supposed to do to keep it from blowing off? Kinda hard to get to that bad boy without dismantling the shit out of it.
What have you done to keep it from blowing off?
post #6 of 16 (permalink) Old 07-04-2011, 08:24 PM
Skierbum's Avatar
Its a pain to fix but with pulling everything i can do it in 30 mins now lol, and I still haven't found a solution other than keep my boost at 20 psi max
Skierbum is offline
post #7 of 16 (permalink) Old 07-04-2011, 08:27 PM
la77chevy's Avatar
I deleted mine Friday and I've boosted over 30 psi several times with no issues. I still can't decide if I'm goin power crazy or what but my truck seems stronger
Brandon
-04.5 LLY, CCSB, 4x4,Silver Birch
-68mm Cheetah, Suncoast stage 4/triple disc converter
-ATS manifolds/Up-pipes, Profab EGR delete, 4''exhaust
-Diamone Eye DP, AFE stage 2, EFI Live (Rob's tunes)
-Airdog 165, Shimmed FPRV, Re-routed PCV, 3'' IC tubes
-Superlift 6'' w/traction bars, heavy duty bumpers
-35'' Nitto Trail Graps on Mickey Thompson Sidebitters
-LBZ MP, Sleeves, N-Fab step bars, HID's
la77chevy is offline
post #8 of 16 (permalink) Old 07-04-2011, 08:27 PM Thread Starter
Well that blows. I guess I'll have to start thinking of a fix
post #9 of 16 (permalink) Old 07-04-2011, 08:30 PM Thread Starter
We got the Sinister kits that I guess are notorious for blowing that tube off. What kit you got? You may have used the block off plate??
post #10 of 16 (permalink) Old 07-04-2011, 08:35 PM
la77chevy's Avatar
Pro Fab delete tube and LB7 up pipe
Brandon
