lly common problems? - Chevy and GMC Duramax Diesel Forum
post #1 of 25 (permalink) Old 07-05-2011, 02:34 PM Thread Starter
jbplumbing's Avatar
what are some common duramax problems? im shopping around for some lb7 duramaxes and i found a nice lly and a nice lbz, what are common problems associated with the LLY and the LBZ, i know the lb7 has the injector issues,are there any with the later lly and lbz? thanks
jbplumbing is offline
post #2 of 25 (permalink) Old 07-05-2011, 02:41 PM
colton3's Avatar
LLY's turbo mouth piece is restrictive. easy fix.
head gaskets are prone to go out...
injector wire harness rubs. thats an easy fix also.
i think there might be one more just cant really remember.
LBZ's dont really have any problem with them. they have the six speed which is a pro.
2008 3500 CCLB Z71 LMM: 4" tuff country lift/ EFI/ deleted/ 5" MBRP & DP/ FASS 150/ CTS
2005 3500 CC Dually LLY
LIFT: 10" third coast/39.5/13.5/R16/super swamper IROKS/ eagle alloys/456 gears
MODS:diablo sport predator/egr blocked/4'' straight pipe/LBZ MP/ppe boost valve controller
colton3 is offline
post #3 of 25 (permalink) Old 07-05-2011, 02:43 PM
saw what you did there
theunderlord's Avatar
cue * get the newest one you can afford.
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #4 of 25 (permalink) Old 07-05-2011, 02:44 PM
Administrator
jc1843's Avatar
The LLY -- 04.5--05 years had a connection problem with the injectors, and a wear through on the FICM harness-- both an easy fix. Less common is some higher mileage trucks lost the head gaskets.
The 06-- can be a LLY or a LBZ--same engine and all parts-- the LLY had a mild tune. No real problems-- probably the best Duramax
jc1843 is offline
post #5 of 25 (permalink) Old 07-05-2011, 02:44 PM
la77chevy's Avatar
LLY also has the FICM harness rub, also an easy fix. Pump rub is also an issue, but not limited to the LLY, I think they all suffer from it.
Brandon
-04.5 LLY, CCSB, 4x4,Silver Birch
-68mm Cheetah, Suncoast stage 4/triple disc converter
-ATS manifolds/Up-pipes, Profab EGR delete, 4''exhaust
-Diamone Eye DP, AFE stage 2, EFI Live (Rob's tunes)
-Airdog 165, Shimmed FPRV, Re-routed PCV, 3'' IC tubes
-Superlift 6'' w/traction bars, heavy duty bumpers
-35'' Nitto Trail Graps on Mickey Thompson Sidebitters
-LBZ MP, Sleeves, N-Fab step bars, HID's
la77chevy is offline
post #6 of 25 (permalink) Old 07-05-2011, 03:04 PM
lddrew's Avatar
Nbs don't.
-Lee-
LBZ Crew - EFI - MBRP - Profab - Airdog
Raptor lined rockers and flares by me
my "build" thread
Raptor color match thread
ATP Trucks
lddrew is offline
post #7 of 25 (permalink) Old 07-07-2011, 05:26 AM Thread Starter
jbplumbing's Avatar
so what you guys are tellin me is that the lly has its share of small issues, and headgaskets. the lb7 as far as i know is only injector issues, so the best duramax, out of the three is the lbz?
post #8 of 25 (permalink) Old 07-07-2011, 06:10 AM
la77chevy's Avatar
06-07.5 LBZ is the best
Brandon
post #9 of 25 (permalink) Old 07-07-2011, 03:54 PM Thread Starter
jbplumbing's Avatar
lol ill try to find one if my buddy can find one wholesale.
post #10 of 25 (permalink) Old 07-08-2011, 01:09 PM
DarkCharisma89's Avatar
'04.5-'05 also can be prone to overheating. The '06-07.5 LLY/LBZ got a bigger radiator and fan compared to the '04.5-'05 LLY, which only has a small number of sure-fire options, all of which involve adding a secondary cooling system.
Some people have overheaters, some don't... Luck of the draw and what you do with it I suppose. So far I have been really happy with my 04.5 though, and it was at least 5k cheaper than a similar mileage '06 with the LBZ.
Just gas burners now
DarkCharisma89 is offline
