Every now and then when you run the truck it will have a 5-7sec lag to the turbo... but then you turn the key off and start it up again all is good. This will happen every once in a while but not too frequent.
make sure your air intake is clean..i had a similar problem this last week that was a simple fix with a new intake..just a thought
__________________ James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Condition of the boost tubes????Intercooler hoses leaky???idk,jus a thought
__________________ 06.LBZ GMC[SLE1] 4x4 ....114k miles,4136 hours[Modded a bit.LOL]
1987 Monte Carlo SS 89k
1978 Malibu FORMER DURAMAX FORUM MODERATOR...........i HAVE YOUR iNTERNET pROVIDER ADDRESS...:tease
Im around 1900ft... i seen a code saying "Turbocharger under boost" a couple of timez but it does not show up when the turbo lag occurs seems just randomly when i check the codes every now and then
Ive been busy with work as of late... ill do some more investigating tonite or tomorrow
Under boost code shows up when desired boost does not equal actual boost, after so many counts, as in a big lag. But 1900 ft should not be the cause of it.
Once again, EFILive log session, and 10 minutes of digital dissection should suffice.
__________________ Michael, 2500HD LLY, Systems Engineer, EMAIL
