Old 10-17-2008, 09:53 AM   eBay Motors   #1 (permalink)
05 3500 2wd
05 3500 2wd's Avatar
Lift pump required?
At what point do you need to start looking at a lift pump? I am looking at getting a tuner and maybe a tranny so I can run a bigger tune but was wondering what else I will need.
Clifford is a 2005 GMC Loaded SLT 2wd with; Killer Bee true cold air intake and ported LBZ intake overhaul kit, FAE Inter cooler pipe, Diamond Eye down pipe, BD drivers side manifold, Silverline 4" S/S straight piped exhaust, EGR Blocked, PPE On level 2, Bully Dog pillar mounted outlook monitor, 19.5" aluminum wheels with factory lug covers, Goodyear G647RSS 225/70/19.5, BFXenon 6000k Headlights Low & Hi, Air lift Remote control 5000# air bag system, Rear mounted under the bumper halogen lights, EX down Tailgate assist, Put co S/S mud flaps, compete interior wood dash kit, Dual Liner 3 piece bed liner with rubber floor mat, Roll-N-Lock tonne cover with tail gate lock, and AVS in channel vent visors.
05 3500 2wd is offline   Reply With Quote
Old 10-17-2008, 09:56 AM   eBay Motors   #2 (permalink)
gya0ma7ha
gya0ma7ha's Avatar
Depending on what kind of power you wanna run, if your tranny can take it. If you use a bought tuner from like banks, quadzilla, or PPE, you shouldn't need a better or secondary fuel pump, just keep that fuel filter changed.
2001 2500HD LT CCSB 4X4 LB7 TAPE DECK INCLUDED
Leather, Power everything, Autometer Cobalt Boost and Pyro, HID headlights/fogs, 05' Tailights, De-Badged, Some sound stuff
35" Wrangler DuraTracs on KMC 20" Rockstars and a 6" procomp drop knuckle and black Westin runners.
EFILive tuned with DSP5 for Extra Go-Go Modded intake horn, Banks Big Head wastegate, banks ram-air intake, banks straight pipe
Other TOYS:2005 YAMAHA YZ250F Rat Racing motor Enzo Racing Suspension: Forks and shock
Need List: CP3!!!!
Wish List: Transparts iv, Lift pump, Turbo upgrade.
gya0ma7ha is offline   Reply With Quote
Old 10-17-2008, 09:57 AM   eBay Motors   #3 (permalink)
Meyerperformance
Looking for low 12's.
Meyerperformance's Avatar
If you are wanting to run a larger tune such as a hotter PPE tune. I would consider a lift pump so to take stress off the Cp3 pump. MAke it last longer, and the lift pump will deliever more volumne of fuel.
Tyler
MPF
812.344.4421
We Price Match!
Old 10-17-2008, 10:12 AM   eBay Motors   #4 (permalink)
05 3500 2wd
I am kind of leaning toward the ATS due to the "tunes for the buck". The bad thing is If you have it sooner or later you will try it so I am just trying to figure out where I stand and am go to before I get a tuner / Trans / Lift Pump.......or just be happy and safe with a PPE standard or economy tuner.
Old 10-17-2008, 10:17 AM   eBay Motors   #5 (permalink)
Meyerperformance
Well thats is a tough choice, but if were going with a set-up i would go with ATS cause like you said most bang for the buck.
Tyler
MPF
812.344.4421
We Price Match!
Old 10-17-2008, 10:46 AM   eBay Motors   #6 (permalink)
timespentsearching
timespentsearching's Avatar
id say pretty much anything with a high tune. i can even put my truck into limp with my banks because of low fuel pressure due to not having a lift pump
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline   Reply With Quote
Old 10-17-2008, 10:07 PM   eBay Motors   #7 (permalink)
Durallymax
IMO it never hurts to have a FASS or Air Dog on any tune due to the air seperation and the 2 micron filter.
I of course would suggest the Air Dog FP150 your looking at $539 for that. If you think it will be cheaper to go with the FP100 think again its $10 difference.
Ideally you would do the trans then the lift pump and then the tuner but we all know how that goes.
The "Last Minute Puller"
'03 GMC 2500HD LB7/Allison EC/SB 4x4
Suncoast, EFI Live, S400, Studs, Stock Motor
Badger Truck Pullers Association Member
Thanks to all of my sponsors
Durallymax is offline   Reply With Quote
Old 10-17-2008, 11:11 PM   eBay Motors   #8 (permalink)
BigRedChevy
Super Moderator
BigRedChevy's Avatar
Typically after adding around 120-135 HP the lift pump is a must. It is good to have it before then though, just to take the stress off of the CP3 pump. You will probably need to Shim the FPRV too.
KYLE
2010 Camaro SS LS3 426 HP
Old 10-19-2008, 01:07 AM   eBay Motors   #9 (permalink)
gya0ma7ha
gya0ma7ha's Avatar
I hear alot of guys shimming FPRV, what does it do for the truck, shimming it, not the valve itself.
Need List: CP3!!!!
Old 10-19-2008, 01:25 AM   eBay Motors   #10 (permalink)
daddysLBZ
ONEFASTCOONASS..
daddysLBZ's Avatar
When you get a code for low rail pressure would be the best time..J/K if you adding more than 100hp,do it now...Depends on tuner and your foot too..
06.LBZ GMC[SLE1] 4x4 ....114k miles,4136 hours[Modded a bit.LOL]
1987 Monte Carlo SS 89k
1978 Malibu
FORMER DURAMAX FORUM MODERATOR...........i HAVE YOUR iNTERNET pROVIDER ADDRESS...:tease
