Old 10-23-2008, 11:11 AM   eBay Motors   #1 (permalink)
Paccool
Predator program installed
Installed the 65HP tow/economy tune last night in the truck last night. WOW - what a difference in power!
Now, if it helps with the economy part, all will be well.I'd sure like to get the everyday driving up to 20-21 MPG from the 17.5 I now have and the towing has been at 10.5 and hope it goes to 14 or so.
Question about the tranny though. It shifts funny into 4th and 5th when romping on it, hesitates for about a second or so. I see where folks say to drive it for 50 miles or so and give the tranny time to relearn the shifts. This sound like the right advice?
It also hold back and down shifts like it was in tow/haul mode but it is not. Is this something the predator does when pumping the power up?
Stan
2005 Chevy Silverado 4x4, 285-70-17's on Hummer wheels. 24,000 miles. Banks Ram Air inlet system. Predator programmer, KillerBee modified mouth piece.
93 Dodge D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust,modified tranny,EGT/boost/tranny/tach gauges.Rear sway bar.Single stage Water/Meth system installed. Oversized intercooler
Paccool is offline   Reply With Quote
Old 10-23-2008, 11:15 AM   eBay Motors   #2 (permalink)
daddysLBZ
ONEFASTCOONASS..
daddysLBZ's Avatar
Go through it like this...do some 1/4 throttle shifts,then 1/2 then 3/4 then wotnot all in one day though.I'd say the relearn takes 200 miles,but def more than 50 before you romp on it...you need to have it in tow/haul while you gettin on it too..When you don't have in tow mode,drive sensibly.
06.LBZ GMC[SLE1] 4x4 ....114k miles,4136 hours[Modded a bit.LOL]
1987 Monte Carlo SS 89k
1978 Malibu
FORMER DURAMAX FORUM MODERATOR...........i HAVE YOUR iNTERNET pROVIDER ADDRESS...:tease
Old 10-23-2008, 01:55 PM   eBay Motors   #3 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
if it is hanging on shifts, it could be the fuel filter. if it is only hanging and shifting slow, it is defueling to save ur tranny....the truck does this stock too, with a programmer it does it more pronounced. As long as it shifts without letting up on the go pedal, it probably is just defueling.
Old 10-23-2008, 03:04 PM   eBay Motors   #4 (permalink)
Paccool
Got a new fuel filter on it about 1500 miles ago. Did that right after I bought the truck.
I hope this shifting issue goes away so I can enjoy that new power!
Stan
