Just installed the KB CAI & OIK. By cutting the bottom hole out in the foil, will I have to watch for extra dust and snow getting into the air box.
Also how can you tell if the the mouthpiece is up against the turbo at the bottom after the clamp is tightened
Will the air box have a bit of movement once installed.
I checked everything after driving it and the air box does not seem to be perfectly tight against the fender,. When tight the back 2 pins are about a half inch towards the firewall from the gromits.
Did some testing by the speedo.Up a hill stock 145km same with CAI & OIK. Quarter mile 135km for both.Was not expecting to see much of a difference.
Did a 200mile trip and driving110km the mileage was still the same,there was a wind so I will have to check it some more.
__________________ 05 crew cab 55000miles
2 inch level kit with 265s
Diablo Sport
KB CAI & IOK
4" Magnaflow T/B SS
Plugged Resonator
67 GTO 467cid 615hp (pump gas)
99 700 Mach1 Ski-doo full race 180hp
Would love to see some pictures. I am waiting on my IOH kit to come from him so I can install it and been thinking about the True CAI.
MadJack Racing & Synthetics MadJack Racing is Your #1 Source For Amsoil And Discount Diesel Parts
Credit Cards Accepted
I see tou have the BD manifolg ordered, what is the advantage of that.
To even up the output of the exhaust manifolds. The drivers side has a big restriction and the BD if full flow. It will lower Egt's on that side also. Most people putting out high HP run one. I am towing a heavy load most weekends so I put a lot of stress on the engine. The best part it is already drilled and tapped for a pyro.
Just installed the KB CAI & OIK. By cutting the bottom hole out in the foil, will I have to watch for extra dust and snow getting into the air box. It shouldn't be an issue if you are using the correct element.
Also how can you tell if the the mouthpiece is up against the turbo at the bottom after the clamp is tightened if it doesn't move when you try to rotate it, the v-band clamp has done its job.
Will the air box have a bit of movement once installed. I checked everything after driving it and the air box does not seem to be perfectly tight against the fender,. When tight the back 2 pins are about a half inch towards the firewall from the gromits. this one even gets me. it is not installed correctly. When it is, thos pins find homes in the grommets. You have to pull the box toward the fender and the headlight at the same time. Make sure the rubber shroud is tucked inside the radiator support so it doesn't make an obstacle.
__________________ Michael, 2500HD LLY, Systems Engineer, EMAIL
For $300, I'll come over and drill / tap one hole.
Thats ok Bob thanks for the offer but the manifold is on the workbench waiting for my KB IOH so I can do it all at once.
