Originally Posted by toypuller Ok I have read lots on kbs mouthpiece mod. I want to get some things stright. I have a stock 05 lly intake system and mouthpiece. To overhaul the mouthpiece What exactly to I need to buy? What baffels are people removing exactly? Thanks | its just the turbo mouthpiece nothing else. the kodiak on it alot larger and allows you to flow way more air with less restrictions. as for the baffels thing, it gets rid of the piece that goes to the turbo resignator making more whistle and you dont have to worry aobut trying to plug it if you wanted to do so
__________________ Pickup: 03 GMC 2500HD EXT Cab Long Box
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
Exterior: Stainless rocker panels, Stainless punched grill, TTT-Mirror pull out towing mirror (highly recommend over any other mirror period), Spray in bed liner, B&W Hitch |
