Old 12-20-2008, 10:31 PM   eBay Motors  #11 (permalink)
Super Moderator
BigRedChevy's Avatar
Yes you can run that level with only those mods, but i would also suggest some guages to keep an eye on things. And if you are going to do any 4x4 driving get some tie rod sleeves. It won't hurt your engine to run that level all the time, but i would lower it to tow or your EGTs will get out of hand fastt.
KYLE
2010 Camaro SS LS3 426 HP
Old 12-20-2008, 10:46 PM   eBay Motors  #12 (permalink)
poyse2b3's Avatar
what are the peak EGTs that you would want to see out of a setup like that? so what mode would you recommend just cruising in? and what for towing? and obviously max for racing. but what if i am just cruising and i come across some dillhole who wants to race can i jump to a higher setting on the fly or do i have to turn the truck off and change the setting with the ppe
2005 LLY Grey CC/SB
Performance- PVC Reroute, Resonator delete, 4" Turbo Back, Predator 100hp tune
Looks- 6" Pro Comp Lift, 20" Kruz with 35" Terra Grapplers
Wanted- EFI Live, Suncoast Stage IV, BD Manifold, PPE Race Fuel Valve, FASS 150, Crank It Up Centerlink/Tie Rods, KB TCAI/IOH Kits, EGR Delete, Pyro/Boost Gauges... And More
poyse2b3 is offline   Reply With Quote
Old 12-20-2008, 11:13 PM   eBay Motors  #13 (permalink)
Super Moderator
I have seen 1700 on my egts, but only for a short short time. For extended periods like towing i would not want to see over 1250 degrees. For what level to run, i like running a big tune for daily driving and racing. For towing i would only run a 90 or 120 HP tune if you have a built tranny and just watch the egts. you cannot change the tunes on the fly with PPE and have to shut down the truck each time.
KYLE
Old 12-21-2008, 07:48 AM   eBay Motors  #14 (permalink)
poyse2b3's Avatar
how about gas millage with a big tune? will you get good millage as long as you keep your foot out of it or do you need to drop it down to get better millage?
2005 LLY Grey CC/SB
Old 12-21-2008, 08:08 AM   eBay Motors  #15 (permalink)
Diesel Performance
Meyerperformance's Avatar
Yes the mileage will be the best on the higher settings, takes less effort to get the truck moving.
Tyler
MPF
MPF
812.344.4421
AFE Mouthpieces in stock!
Price match Guarantee!
07.5 Duramax: Garrett 4094vvt, Transparts Stage IV, Autometer SC II's, AFE ic pipe, BD manifold, Diamond Eye DP, S&B, AD150, EFI Live
We use what we sell!
Old 12-21-2008, 08:38 AM   eBay Motors  #16 (permalink)
poyse2b3's Avatar
so why does the ppe have 10 power levels? why would anyone want a mid range level? i mean if you get best performance and millage on the highest?
2005 LLY Grey CC/SB
Old 12-21-2008, 08:43 AM   eBay Motors  #17 (permalink)
Diesel Performance
Because not everyone wants to run the highest settings.
MPF
812.344.4421
Old 12-21-2008, 10:35 AM   eBay Motors  #18 (permalink)
i have the ppe hot 2 and i can run mine on level 10 with no prob i also have a lift pump, and mine is the lb7 which might make a diff
RIP totaled 2004 GMC LB7, EC, SB,
Mods
Programmer PPE hot et2 stacked with mp8 fuel box, Exhaust 7" miters, Turbo PPE Boost Valve. PPE tie rod sleeves, built tranny tcs tc and tts valve body, air dog 150 fuel system
gmc_dmax89 is offline   Reply With Quote
Old 12-21-2008, 11:48 AM   eBay Motors  #19 (permalink)
blackdeath's Avatar
it does say on the site with (supporting mods)
2008 silverado dmax LTZ, aFe stage 2,suncoast stage 4,1056 converter,race tune from idahorob,EFI LIVE, AD 150 lift , ppe shim kit,dpf delete,EGR block off plate,autometer gauges (cobalt) boost and pyro,transgo jr,6"fabtech with maxxcams and 2"addleaf,fabtech tierods,37"procomp 20" boyd wheels. 5% tint all around,5"grandrock stack kit,straight piped, custom painted dash panel,
2008 trailblazer ss, straight pipe ,jetttstream air intake,iat relocate kit,efi tuned , 3" lowered
blackdeath is offline   Reply With Quote
Old 12-21-2008, 11:53 AM   eBay Motors  #20 (permalink)
i meant that i dont have duel fuelers and stuff like that
Mods
