so i am new to this and i am wondering if i get the PPE hot +2 and set it on level 10 will my engine produce an extra 425 hp? i am confused on how that all works thanks for the help
Looks- 6" Pro Comp Lift, 20" Kruz with 35" Terra Grapplers
Wanted- EFI Live, Suncoast Stage IV, BD Manifold, PPE Race Fuel Valve, FASS 150, Crank It Up Centerlink/Tie Rods, KB TCAI/IOH Kits, EGR Delete, Pyro/Boost Gauges... And More
on the ppe the hp gain is at the flywheel. so yes if it says 425 extra that's what you'll get. Keep in mind the tranny will not hold for long at that.
__________________ 2008 GMC EC LB Dually 3500HD with a Reading Classic Utility bed.
4" MBRP SS TB Exhaust
PPE with DPF delete
more coming soon
i wouldn't advise it with a stock tranny. def. not the 5 speed! about 100 extra ponies is all it can take before you start having tranny slipping or going in to limp mode. if you are power hungry, check on a sc tranny level 4 or 5.
__________________ '05 2500hd cc sb 4x4
Dmax 6.6turbo/Allison
Stealth 2, EGR blocked, PVC rerouted, kodiac mp
autometer sportcomp gauges
B&W gn hitch and 5th wheel conversion
5% window tint, gm nerf bars, remote start
kitty stays in the shop
Engine will support the higher level tunes but only briefly before you run outta of fuel and throw a rail pressure code, you will need a lift pump to keep up. But as the other guys said your weak point will be the transmission
i have an 05 and i put it on level 5. I did put a shim kit in the fuel rail. You will need that to run a level that high. Anything after level 3 mine would throw a code until i shimed it
If you installed level 10 on a other wise stock truck you will not get 425 hp even at the crank. In order to see the 425 HP you would have to have lift pump (fuel pump), Fuel pressure relief valve shimmed, exhaust system, turbo upgrade, and dual fuelers. Level 9 (350 HP) is the most you can run without the dual fuelers and turbo. The engine internals are good up until about 600-650 RWHP.
Like they stated, your stock tranny would not last since it is only good for a 90 HP increase.
__________________ KYLE
2010 Camaro SS LS3 426 HP
I put the ppe standard on my truck. In level 4. the 225hp tune. I work at chevy and knew this was going to cause a problem. I broke my torque converter within 600miles of installing it. My truck only had 41k on the truck. The tranny to replace was 5200.00 is what gm paid to fix it. You will blow that tranny right apart. If I can do it in 225hp mode you can really do it in 350hp mode.
__________________ 2005 LT 3500HD CCLB SRW LLY EFI LIVE TUNED BY IDAHOROB TCM TUNED BY MMLMM
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Mcculloch 5300k HIDS
so you can actually run on level 9 with only a tranny, lift pump, exhaust and valve shim? i am going to be using the truck mainly for cruising around but towing a little and showing off to buddies on the weekend. will i get the best performance as well as millage if i leave the ppe on the highest possible setting and keep my foot out of it or is that bad for your truck to leave it on such a high setting?
