? about 5 inch exhaust ? - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 11-22-2012, 05:32 PM   eBay Motors  #11 (permalink)
Down pipe is worth it for the change in sound. No more un-Godly screech at WOT. It also doesn't require transmission removal to change.
I would look into either a Flo-Pro, MBRP, or a Husker Kit. My DE fit like absolute shit, I now have a MBRP 5" straight kit and it fits 100x better than the DE. Might just be me, but those are my recommendations.
2k4.5 GMC D/A...
outlawed_LLY is offline   Reply With Quote
Old 11-25-2012, 03:02 PM   eBay Motors  #12 (permalink)
Originally Posted by Countryboy22 View Post
Ok so the 5 inch kit will mount right up to the turbo and use factory hanger locations? Then i would also need a tip right
No, you need a new downpipe if you want to go right off the back of the turbo, all you need to do is remove the 2 bolts holding the transmission dipstick to get enough room to remove the downpipe. 3 bolts on the turbo heat shield then just flip that back, undo the clamp and the top and bottom and it should pop right out.
05 LLY
EFI Live
Built Trans
Built Front End
Supporting Mods
andy-stevenson is offline   Reply With Quote
Old 11-25-2012, 04:47 PM   eBay Motors  #13 (permalink)
Cknight199's Avatar
When companies say "turbo back exhaust" they mean from the down pipe back. The stock down pipe is 3" I think... The companies count the downpipe as part of the turbo, hence the name "turbo back exhaust" just means it cuts the cat out.
2006 LBZ CCLB DRW
Suncoast Trans w/ 1056
Billet Garrett 4094
BTLockup Box
Built Front End
Some More Stuff
EFI Live by Starlite Diesel
Fastest 1/4 yet: 13.606 (fourth time down the track)
Cknight199 is offline   Reply With Quote
Old 11-25-2012, 05:59 PM   eBay Motors  #14 (permalink)
It may be 3" but they squish it down quite a bit in spots, there's pictures comparing the stock to aftermarket and you can see why so many people do it.
05 LLY
EFI Live
Built Trans
Built Front End
Supporting Mods
Old 11-25-2012, 06:04 PM   eBay Motors  #15 (permalink)
Cknight199's Avatar
Yea it's 3" but almost bent in parts so it doesn't flow like you think it would... Thanks for clarifying
2006 LBZ CCLB DRW
Billet Garrett 4094
BTLockup Box
Built Front End
Some More Stuff
Old 11-25-2012, 06:39 PM   eBay Motors  #16 (permalink)
IGOU's Avatar
Originally Posted by 86burgandyss View Post
I have a bullydog turbo back on mine sounds great and has lasted 600,000 miles plus
Wow, Rodger. I guess I never noticed how many miles you have on your truck. That's awesome!
Robert,
'03 Silverado, CCSB, 4WD 2500 HD,
20% injectors, ADII 165, K&N drop-in air filter,
buckstop bumper, w/ Warn powerplant winch, and PIAA fogs.
Rear airbags.
'02 CCLB 2WD 2500HD
white, stock w/t w/ ZF-6
(new to me) (loving this ZF-6!)
IGOU is offline   Reply With Quote
Old 12-03-2012, 06:24 PM   eBay Motors  #17 (permalink)
Raisingkahne's Avatar
I just did DE down pipe and DE 5" straight exhaust. The 5" is actually 4" until it gets to where the cat is. That is where it bumps up to 5". Spray all of the nuts and bolts the day before with PB blaster. Take your time and be patient. I hated my DE exhaust the first night, it just did not fit correctly. I went in for the night and had a couple beers and thought about it. Got up the next morning with a clear head and everything fell into place. I could not be happier.
05' LLY CCLB 2500 HD 4x4
Leveling Kit, 285/75/R16 Toyo M/T
EGR Delete, Delete Pipe
DE down pipe, DE 5" straight exhaust
PCV Re- route
Kodiak MP
Edge Insight CTS
EFI Live. Tunes from Rob. New trans from Mike.
Raisingkahne is offline   Reply With Quote
Old 12-04-2012, 06:48 AM   eBay Motors  #18 (permalink)
I just installed a 4" MBRP DP or turbo back exhaust with a 6" tip, nice aggressive sound with the MBRP through muffler, no excessive cab noise and nice boost in acceleration. I haven't done the down pipe yet but thinking of going with the the MBRP 3"....installation time on the exhaust on a lift was about 2.5hrs total-removal and install, no issues at all with this system...
Black '05 Chev CC SB-8'6" Hiniker V-plow-4" MBRP DP back exhaust-6" tip-AFE Bladerunner turbo intake & K&N drop in air filter...100K-barely broke in!
DMax74 is offline   Reply With Quote
Old 12-04-2012, 06:55 AM   eBay Motors  #19 (permalink)
The S.O.M.'s Avatar
Stock Compared to Profab Downpipe
The Sound Of Madness
2004.5 LLY ECSB
EFI Live, MA700 Trans, Airdog 2 165, MBRP 5" with 6” tip, Profab Downpipe, LML Manifold, LBZ Mouthpiece, AFE Stage 1 Intake, EGR Blocked, PCV Rerouted, Resonator Plugged, ADP Race Valve, MA Rear Housing Support, MA Pump Rub Fix, Rancho RS9000xl's, Amsoil Synthetics, Autometer Cobalt’s Boost & Pyro, Tint (5% back, 20% front), HID's, US Speedo Custom LED Gauge Cluster, Line-X’d rockers
To Come!! :
Profab EGR Delete
4094vvt
40% overs
The S.O.M. is offline   Reply With Quote
Old 12-04-2012, 03:13 PM   eBay Motors  #20 (permalink)
04NC_DMax's Avatar
I put a 5" Diamond Eye on mine, the fitment was horrible. I ended up welding it up and using only 2 of the hangers/clamps that came with it. I will not buy from them again, but it sounds good though. I doubt brand has anything to do with the sound though lol.
2004.5 Chevy 2500hd CCLB 4x4 LLY Duramax
Old and Gone
1999 Dodge 2500 12.83@105 1/4 mile
2006 F350 14.01 1/4 mile
04NC_DMax is offline   Reply With Quote
