| 04.5-05 LLY Performance Parts Discussion Discussion of Performance Parts For the 04.5-05 LLY Duramax Trucks No Advertising |
| Junior Member Join Date: Aug 2011
| ? about 5 inch exhaust ? I am thinking about straight piping my truck with that being said I would like to do a 5 inch exhaust and 6 inch tip. So my question is first do I just need a turbo back kit and down pipe? And second question is I see a lot of people running four inch what differences are there or is it simply just size. ???? Also what brand should I go wit flo pro , diamond eye? Do you guys recommend stainless or aluminized ?
__________________ 2005 Gmc sierra 2500HD with 6 inch pro comp lift and 35;s with amp research steps. SOLD.. 05 Tacoma 4x4 Looking for Lbz or Lmm! |
| I just put a 5" diamond eye exhaust kit on my 2003 duramax and it sounds awesome it's just turbo back. If you go with a down pipe (which would be very awesome) you will have to remove the transmission as well so it's kind of a pain in the ass. And for type of metal, steel all the way. And for brans, everyone has their preference, but diamond eye has been the best I've read on, and sounds amazing. |
| DuramaxForum Enthusiast ![]() Join Date: Apr 2010 Location: fairfield,ca
| You don't have to remove the transmission to do the downpipe, I literally just did mine and you don't have to. it can slide up and out with the transmission still in.
__________________ CHAD : 2002 CHEVROLET 2500HD ec/sb 4x4: Has enough to help me do the speed limit 30% exergy,s366,alligator stage 5, Idaho rob, arp studs, 6" tuff country 35x12.50 nitto trail grapplers, 17x9 xd spies all work done at home ![]() Building a gas engine and need a dry sump oil system?check out A.R.E drysump.com gold star of excellence award winner 2011 a proud owner of a pound seven |
| Thank you I have been thinking about a downpipe but someone said I had to remove my transmission but I'm glad you said I don't need too. Is it worth is?
__________________ 2003 Chevy duramax, 5" turbo back diamond eye exhaust, afe intake, halo headlights, EFI live tuning by Idaho rob. |
| The downpipe? yeah it's worth it, adds spool up and less egt's. I took my mbrp out of the top no problem and put the new one that came with my turbo in. now the transmission out makes it a lot easier, but it's not as bad as you would think from the top....but yeah they lied to you..just need ratcheting wrenches 12-15mm
| So I can order a 5 inch turbo back kit and that's all I will need?
| Senior Member Join Date: Apr 2012
| and add a downpipe if ud like one..
__________________ 2010 2500 ccsb dpf delete - egr blocked - cheap pcv re-route efi live tuned dsp5 - by rob! 4" Diamond eye duals afe intake with pro dry 2 ride rights edge insight cts w/ egt probe and two backup cameras Dirty Loud and Proud |
| Ok so the 5 inch kit will mount right up to the turbo and use factory hanger locations? Then i would also need a tip right
| DuramaxForum Veteran Join Date: Aug 2012 Location: SLC, Utah
| Quote:
__________________ 2006 LBZ CCLB DRW Suncoast Trans w/ 1056 Billet Garrett 4094 BTLockup Box Built Front End Some More Stuff EFI Live by Starlite Diesel Fastest 1/4 yet: 13.606 (fourth time down the track) | |
| DuramaxForum Veteran Join Date: Jun 2007 Location: michigan
| I have a bullydog turbo back on mine sounds great and has lasted 600,000 miles plus
__________________ Rodger 07 classic crew cab long bed 2wd 2500 650,605 miles on 2-14-13. Rotella T oil. Have replaced entire fuel system, sending unit to injectors, lines included, Waterpump last year, hydro boost, besides that truck is factory original except ujoints and brake pads 3.73 rear, stock tire size bully dog , 5 inch turbo back, with 6 inch tip. rTitan 55 gallon aftermarket tank 115 gallon auxilary tank ![]() 5% tint on all windows, and "eyebrow" on front ![]() 86 burgandy Monte Carlo SS Last edited by 86burgandyss; 11-22-2012 at 04:41 PM. |
