| 04.5-05 LLY Performance Parts Discussion Discussion of Performance Parts For the 04.5-05 LLY Duramax Trucks No Advertising |
| My glow plug light will only come on for a second and then will turn back off, and now that its cold out the truck is struggling to start. What is going on and what do I need to do to fix this?
__________________ 2004.5 GMC 2500HD SLT 4X4 LLY Duramax, 6" Lift, 4" Dual Exhaust, Airdog II System, Volant Cold Air Intake. Last edited by Dev11on; 12-02-2012 at 06:24 PM. |
| Junior Member Join Date: Dec 2010 Location: Michigan
| Tell us details about the truck. Model year, engine, etc.
__________________ 2006 2500HD LBZ 4X4 CC/SB LT3, 265/75R16, Rhino Liner, PCV Reroute, Resonator Plugged, 35w 6K HID Low Beam & Fog Lights, LED Interior Lights, ISSPro Pyro, Boost, & Rail Pressure Gauges in A-Pillar, more to come soon. 1996 K2500 Suburban 7.4L, 265/75R16, Brush Guard, Nerf Bars |
| Its a 2004 2500HD SLT LLY 4X4 |
| OK, the LLY if it has a stock cal, will monitor each glow plug individually. Hook us a scan tool and see if you have a bunch of glow plug codes. If so, repair as necessary. My LBZ just spit out a glow plug out of the blue. I replaced the plug and my problem was fixed. So make sure the Check Engine Light comes on when you turn the key on, if not, that is a good place to start. Then look for codes. These engines are pretty good about telling on themselves. My armchair guess is you need a set of glow plugs, but diagnose them first. Don't throw $160 worth of glow plugs at the engine for the hell of it.
| Might be a fuel problem-- the glow plugs on my LLY cycle fast. Also the LLY does not have as much problem with glow plugs as the LBZ. If you don't have any glow plug codes, I doubt that is your problem. Try pumping the primer on the filter housing, see if that helps it start.
| DuramaxForum Veteran Join Date: Mar 2008 Location: West Central Iowa
| What is your definition of "cold"? Temps please?
__________________ '05 CC/SB, AMSOIL 15w-40 (From Synthetic Motorsports), Cold Air Intake with a dry Nanofiber filter from AMSOIL, PPE Tuner level 1, EGR blocked, LBZ MP, lost KITTY, finished off the rest with 4" SS Magnaflow, Amsoil Torque Drive, 5K HID's, General Grabbers 265 :rockin Synthetic Motorsports |
| Moved to LLY-- truck runs
| No codes, and has brand new fuel pump. Temperatures are in the low 30's to 40's
__________________ 2004.5 GMC 2500HD SLT 4X4 LLY Duramax, 6" Lift, 4" Dual Exhaust, Airdog II System, Volant Cold Air Intake. |
| DuramaxForum Enthusiast Join Date: Jan 2012 Location: SLC, Utah
| Did you actually scan for codes or is the check engine light just not coming on? I have 2 bad glow plugs and it throws a code every time but it does not set the check engine light. I looked at my factory tune in efi live and its not even set to throw the light for bad glow plugs..but it still will store the codes.
__________________ 05 lly EFI Live 4094 vvt Built Trans BT Lockup Box Supporting Mods |
| DuramaxForum Enthusiast Join Date: Sep 2010 Location: Maritimes, Canada
| OP, you need to scan your ECM for codes before we can help you further.
__________________ 2005 Silverado EC/SB, LLY, 4WD, EFI DSP5 V2 (Idaho Rob at ATP), Edge CTS w/ EGT probe, LML Exhaust Manifold, PPE shimmed FPRV, Banks LBZ air cleaner, Profab intake, LBZ Turbo Mouthpiece, Kennedy twin lift pumps w/ megafilter, Corsa 304 SS Exhaust, Mike L tranny cooler, EXAXT Steering System, Redhead Power Steering Box w/ Amsoil PS fluid, Green Torsion Keys, Allison Deep Pan w/ Suncoast Filterlock and Transynd ATF, Bilstein 5100's (Norcal), Cognito UCA's, 17" NBS alloy rims, 265/70R17 Michelin LTX M/S2's, Pioneer AVH-P3200BT, CubbyCam Backup Camera, Pop & Lock Power Tailgate Lock, Extang Solid Fold Tonneau Cover, Tekonsha P3 Brake controller, Alphatherm AT-38OD Washer Fluid Heater |
