Winter Front ? - Page 3 - Chevy and GMC Duramax Diesel Forum
Old 01-14-2013, 06:24 PM   eBay Motors  #21 (permalink)
Jlsiberia's Avatar
FIA cover is perfect fit nice and thick definitely helps to have it here in MN
Jlsiberia is offline   Reply With Quote
Old 01-15-2013, 03:47 AM   eBay Motors  #22 (permalink)
Originally Posted by FarmerBill View Post
I guess I'll have to find an aftermarket one. I talked to a dealership the one for an 04 is discontinued and they said there's not a dealership in the country that has one. Does anyone know what's a good aftermarket one? It would be really nice to have one that opens up in the middle since we can go from warm to cold quite a bit here in Illinois.
Do a search, I found mine on the internet for $75
2004 1/2 ECSB GMC. LBZ Mouthpiece and 2006 Banks CAI
Alan2d is offline   Reply With Quote
Old 01-18-2013, 02:39 PM   eBay Motors  #23 (permalink)
DuramaxSilvy's Avatar
whats this front cover?
never found a need for one. let it run for 15 mins on hi idle and it warms up fine. im talking teens to single digits. i never plug mine in either. starts fine.
its a truck, not a baby.
shit, some days i hop in and go in the 20's. tranny wont shift into 5th until the temps are up to right temp and by the rpm's being higher than normal it helps the process.
2005 4x4 2500HD LLY ECSB
ATP Autocal DSP2 80hp street/40hp tow vvt brake, 4" MBRP Turbo Back, 5" Tip ,AFE Mouthpiece, Fingered, Blocked, All On/Dual Park Lights, Leveled Kool-Vue Tow Mirrors, 18%Tint, debadged, Discoverer AT3's, 2006 Lower Valance, Extang Trifecta
Next:Level kit
DuramaxSilvy is offline   Reply With Quote
Old 01-18-2013, 05:34 PM   eBay Motors  #24 (permalink)
Wiretwister's Avatar
Diesels like heat. Less fuel from idling, better mpg and after what I paid for this thing, I want it to last.
2013 GMC SLE LML Stock
2008 GMC SLE LMM Stock (Traded)
2010 Toyota Tacoma Dbl Cab TRD (Wifeys)
2010 Kubota B3200
2008 John Deere Gator 620i XUV
2003 Mountain Cat 800EFI 144" track
1974 VW Bus Westfalia All original survivor
1970 Toyota Landcruiser Restified (twice) 350 SB Chevy Turbo 350 NP205 Factory rearends, locked
1951 Willys 4WD 1 ton pickup Restored to original
One very patient wife
Wiretwister is offline   Reply With Quote
Old 01-18-2013, 07:24 PM   eBay Motors  #25 (permalink)
TakeEm's Avatar
I said that 2 but at -25 my truck hates me at 70mph down the highway!
Caleb 22
2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard
EFI Live DSP5 by Duramaxtuner.com
5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro
Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports
TakeEm is offline   Reply With Quote
Old 01-18-2013, 07:32 PM   eBay Motors  #26 (permalink)
adamz's Avatar
Ha. northern illinois... its 41 degrees right now, grated next week we get to see some teens... go cheap.. buy a tarp and toss it over the front end. warms up in 5 minutes.
02 GMC Sierra LB7 | Dana 60 | 4.10s | Lifted | 37's |Single Stack | K&N Intake | 90hp Injectors | Edge Juice | HIDS |200k on the clock
To Do: ADII | EFI Live | Head Studs | Built Trans | LED Cab Roof Lights |
adamz is online now   Reply With Quote
Old 01-18-2013, 08:21 PM   eBay Motors  #27 (permalink)
FarmerBill's Avatar
Sure this winter. But it was only a couple of years ago we were below 0 for about a month everybody around here is getting spoiled with the mild winters the last 2 years we're due for a bad one again sometime.
04.5 LLY RCLB
4" Turbo Back, LBZ Mouthpiece, Air Box Mod, EGR Blocker
FarmerBill is offline   Reply With Quote
Old 01-19-2013, 03:52 AM   eBay Motors  #28 (permalink)
They come up on ebay all the time, just make sure you know all the part numbers to search for and you'll get one.
Took off the other day and is was -10F, didn't let the truck warm up enough and it was not liking me at all either. Once I got on the highway I had no trouble getting the truck up to full temp (180F) in about 15 mins though. Up north those grille covers are a must have IMHO.
MTL_Dmax is offline   Reply With Quote
Old 01-19-2013, 08:12 PM   eBay Motors  #29 (permalink)
KB3MMX's Avatar
Nice to not lose heat nearly as fast after keyoff too...
Ham Radio= Global communications without airtime fees
My Antenna-SteppIR
Si Vis Pacem, Para bellum !!!!
07' Chevy Silverado HD --CC, SB 4X4 Duramax Diesel/ 6 spd Allison Auto (PTO high idle mod)
--EFILive tuning by ...ME with 68MM 4094VA Garrett Powermax Stage 2 Turbo
--SILVERLINE 4" Stainless Exhaust, Modded stock Airbox and LIBERATOR Stainless Downpipe
--AMSOIL Synthetics and filtration bumper to bumper, including Bypass
--DDM tuning HID's in Low and High Beams, 6000K Lows/4250K Highs
--PPE rear Diff cover, PPE Deep Trans Pan, PPE High Flow Manifolds and Up Pipes
--Danville 3" Y Bridge and big air intake kit / EGR delete
KB3MMX is offline   Reply With Quote
