Won't start in the cold! - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 01-23-2013, 03:10 PM   eBay Motors  #11 (permalink)
boostnlb7's Avatar
my motor has 20,000 miles in it, brand new injeciotrs and cp3 pump, new FF too, 15w40 rotella T, original glow plugs and batteries that are almost 4 years old, well one is over 5 and the other is almost 4, its been 0 or below here and without plugging mine in at all it wont start, if i plug it in for a half hour it starts.. i know my batteries are weak because i can tell when im cranking it.. im not sure if i hav a combination of weak batteries and glow plugs tho.. when it starts it rattles like a cummins, but not if i plug it in all night..im gonna try batteries first..any other ideas?
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
Old 01-23-2013, 03:13 PM   eBay Motors  #12 (permalink)
Is this your first diesel/Duramax? If so, are you priming it correctly by removing the bleeder screw? If so, Im with everyone else about fuel being jelled up.
2006 Silverado CCSB LBZ
1995 Tahoe (Off Road Truck)
1984 Monte Carlo
1969 Camaro (Still in the Works)
Wantamax is offline   Reply With Quote
Old 01-23-2013, 03:13 PM   eBay Motors  #13 (permalink)
Bosis21's Avatar
if its the batteries i would take it back to the dealer and put up as stink as you literally just bought it, and if they arnt jews and want repeat business they will put new batteries in for you as they probably already knew they were junk but just charged them up for a quick fix to sell the beast
2012 DENALI HD
XRT Pro - 5" Flo Pro SS - S&B Dry
CTS Insight w/ Pyro - Barracuda Bypass
AMP Power Research Steps - Leveled
12" Alpine w/ Clarion Amp
Bakflip fibermax w/ Tonneau B-lights
ANGELL'S FISHING&HUNTING OUTFITTERS - AMISK LAKE SK. http://www.angellsfishandhunt.ca/
www.TrollPerformance.com
Bosis21 is offline   Reply With Quote
Old 01-23-2013, 03:30 PM   eBay Motors  #14 (permalink)
JZK01's Avatar
yes this is my first diesel, and i have loosened the bleeder screw once or twice but not everytime i prime it.. Am i supposed to lossen it everytime?
JZK01 is offline   Reply With Quote
Old 01-23-2013, 03:51 PM   eBay Motors  #15 (permalink)
07GMCLBZ's Avatar
Yea you gotta loosen it everytime until straight fuel comes out. Pump it about 10 times give or take and crack the bleeder.
07 GMC CCSB CLASSIC LBZ
EFI Live DSP5
EGR blocked, PCV Reroute
MBRP DP
4 inch MBRP straight
ReadyLift keys/ 1" blocks
Moto Metal 951's
285/75-16 Nitto Terra Grapplers
07GMCLBZ is online now   Reply With Quote
Old 01-23-2013, 04:51 PM   eBay Motors  #16 (permalink)
JZK01's Avatar
just gave that a try again, still wont fire up.. ill replace the fuel filter tomorrow hopefully that works even though im pretty sure it was done not to long ago.
Old 01-23-2013, 04:55 PM   eBay Motors  #17 (permalink)
Salt sucks
WVRigRat05's Avatar
Just built mine, took it to my guy to have some shit checked out I didnt replace the glow plugs, and 3 were shot. It was 8* this moring sounded like a champ with new glow plugs.
Reger
Black on Black 05' Silverado 2500 HD 4X4 CC/SB, LBY7, LT. 8580 lbs
Motor died 1/19/12 190.131 mi.
Trans. died 7/27/12 200,136 mi.
Built motor/Trans and tuned by Blackout Performance
some parts to take it.
2011 30' Puma KDBSS
WVRigRat05 is offline   Reply With Quote
Old 01-23-2013, 06:23 PM   eBay Motors  #18 (permalink)
you have to have very strong batteries. They have to be able to spin the engine pretty fast ( about 150 rpm) and still have about 10.5 volts to fire the electronics. load test the batteries, if they won't hold a charge and pass a load test, replace both. Charge both overnight before installing them.
05 4X4 CCSB LLY w/Ally w/147K
Edge Juice / Attitude
AME Brute Force Intake w/ MP
Optima Red Tops
Kenwood w/ Alpine Kicker & speakers
Over 500k diesel miles since 1995
Banjo Willy is offline   Reply With Quote
Old 01-23-2013, 06:33 PM   eBay Motors  #19 (permalink)
boostnlb7's Avatar
Thanks guys.. My glow plugs hav 265k on them, i think.i will just replace glow plugs and batteries all im one shot.. That should do the job eh?
Old 01-23-2013, 06:36 PM   eBay Motors  #20 (permalink)
the SLEDGEHAMMER
2500-HD's Avatar
as a test over the past few days of single digits, i cold started a few times without glow plugs...cranked the same as if i waited the extra second.
04.5 2500hd
2500-HD is online now   Reply With Quote
