How do you know--ice pick trick - Chevy and GMC Duramax Diesel Forum
Old 01-23-2013, 09:02 AM   eBay Motors  #1 (permalink)
How do you know if you need to do the ice pick trick to your injector harness? What are the signs of it being a problem?
Built 2005 LLY Duramax 4x4
White (blacked out), crew cab, short box...
*Built tranny.
*BD supermax s300 turbo kit.
*MBRP 5" straight piped. 7" tip
*EFI LIVE-GOS Performance.
*Edge CS Insight and boost in pillar.
*AFE Turbo Manifold. S&B intake.
*PCV Rerouted. Fresh FPR. EGR blocked.
*5% tint, wheels, fusion bumper, led tails/third, etc
screech is offline   Reply With Quote
Old 01-23-2013, 09:11 AM   eBay Motors  #2 (permalink)
strutindmax's Avatar
It will sound like an Isuzu box truck with no power.... And your cel will come on
Sent from AutoGuide.com App
04.5 LLY CCSB, EFI blocked, plugged and routed, AFE intake and mouth piece, CTS Insight, 4" Silverline, Fabtech 8 w/ Toyo MT 37, front end built, fully loaded and not enough
strutindmax is offline   Reply With Quote
Old 01-23-2013, 09:13 AM   eBay Motors  #3 (permalink)
xsivspeed454's Avatar
It doesn't have hardly any power either
Sent from my iPhone using my iPhone
2003 CCSB 4x4
EFI Tuned by ATP -PPE Stage 4 -Silverline 4" Exhaust -MBRP Downpipe -PPE Boost Valve -CAI -Ported Intake Horn -Ready Lift Leveling Kit -Autometer Boost & Pyro -Airdog II 165
xsivspeed454 is offline   Reply With Quote
Old 01-24-2013, 01:54 AM   eBay Motors  #4 (permalink)
05DmaxxLLY's Avatar
You'll have no power when you hit a hill (mine dropped down to 35 on the highway anytime i hit any kind of an incline), and like stated above, it sounds like an old box truck when its idleing. It really cant be mistaken for anything else once you hear it. If it didnt happen yet, carry an ice pick with you in your truck. I wish i had done that, instead i limped it home.
2005 Duramax LLY
AFE Intake Elbow-Alligator Performance PCV Re-route-Ready lift leaveling kit- Anzo black parking lights and smoked cab lights-BD Diesel Turbo Timer-Pro Comp 285/70/16
MUCH MORE TO COME!!!
05DmaxxLLY is online now   Reply With Quote
Old 01-31-2013, 11:15 AM   eBay Motors  #5 (permalink)
what is the ice pick trick?
04.5 LLY, 4" exhaust, no cat, Edge Juice with attitude, PVC reroute, AFE turbo mouth piece, AFE intake...
115000 miles
EGR block off plate(Done and Done), with finger stick on the bench waiting to be put in....
Just had to do the dreaded head gaskets on it, ARP studs, EGR block off, cleaned out intake, new water pump.....
oldbluechevy78 is offline   Reply With Quote
Old 02-25-2013, 01:37 PM   eBay Motors  #6 (permalink)
so what is the ice pick trick?
johnlapierre is offline   Reply With Quote
Old 02-25-2013, 04:42 PM   eBay Motors  #7 (permalink)
rd05lly's Avatar
You use ice pick on injector plugs mainly 2 and 7 so they make good contact with injectors again. Should also check wiring at alternator bracket at same time.
05 CCSB EFI Live by Kory Willis
76 Dodge Charger SE
http://www.duramaxforum.com/forum/at...volunteers.pdf
www.TrollPerformance.com
rd05lly is offline   Reply With Quote
Old 03-29-2013, 10:15 AM   eBay Motors  #8 (permalink)
You will know for sure. Mine crapped out 10 miles from home after a 500mile round trip, (lucky me) it had little or no power and barely made it to my driveway. it sounded like a farm tractor too... I made an ice pick and poked #2and #7 and she ran perfect. At first I tried just cleaning the connectors and it did not help.
2004.5 LLY Silverado LT C/C S/B
Magnaflow 4" Turbo-Back
LBZ Mouth Piece
Custom CAI
Cranked T-Bars
jimzdmax is offline   Reply With Quote
Old 04-01-2013, 08:03 PM   eBay Motors  #9 (permalink)
ramrod04lly's Avatar
what is used to make the ice pick? whats a good suggestion for something, how hard do you "poke"? my truck has a bad injector knock currently but hasn't lost any power so i'm trying to figure out what to do to fix it.
04 LLY 72k miles
EFI LIVE 100HP Tune
5" Diamond Eye Turbo Back
5% Tint
17" Moto Metals with 285's
HID's 8k heads and 10k fogs
Timken Hub Assembly's
Bilstein 5100 Shocks
Debadged
ramrod04lly is offline   Reply With Quote
Old 04-01-2013, 08:06 PM   eBay Motors  #10 (permalink)
e46_330i's Avatar
Umm. Use an ice pick? Lol
2004.5 Sierra SLT 4WD CCSB Black/Black
Studded, Deleted, Re-Routed
FPRV Race Valve
LBZ FPR
20x10 ET -12 Fuel Hostage
Nitto 420s 305/50/20
All-On Mod
MA Pump Rub Kit
3" DE Down Pipe to a 7" Single Mitre Cut
EFI Live DSP5 By Kory "Supa Tuna" Willis @ PPEI
e46_330i is offline   Reply With Quote
