Benefits of egr - Chevy and GMC Duramax Diesel Forum
post #1 of 80 (permalink) Old 01-24-2013, 02:34 PM Thread Starter
05dmax89's Avatar
Benefits of egr
Gonna do the egr delete was just wondering Wat are the benefits of doin it
2005 LLY
AFE intake/6" procomp lift/extra rearleaf spring/4" straight pipe to 5" tip/35x12.50x17 Mickey Thompson MTZ /procomp wheels/airdog 150/lbz mp/pcv reroute/big air kit/sulastic shackles/ bilsteins 5100/reacon interior lights/frontier bullnose bumper/ lml manifold/kryptonite control arms/stage 2 frontend/efi by kory/edge insight/gmax 5 wit precision tc/cat adapter filter
92 12 valve
4 in diamond eye/he 351cw/nv 4500
05dmax89 is offline
post #2 of 80 (permalink) Old 01-24-2013, 02:44 PM
Farmer93's Avatar
I just did mine and egts dropped a little and it really cleans your intake. My truck had 165,XXX on it when I did mine and it was awful looking. It took me forever to clean my intake. It will be so much better for your truck. Also now is a good time for a pcv re-route. There is a DIY thread on it.
04LLY. K&N Intake- EFI Live 5 position by IdahoRob-Sinister Diesel EGR Delete- PPE stage V tranny- Triple Disk Converter- MBRP 5 inch Stainless to an MBRP Monster 8 inch tip- resonator plugged- 3 inch intercooler pipes- Profab y-bridge- S&B mouthpiece-FASS 150gph- Autometer Sport Comp 2 Pyro and Boost guages- Cognito leveling kit and UCA's- PPE Tie Rod Sleeves- Empire Diesel Center Link- Rough Country Add-a-Leaf- Bilstein 5100's Front and Rear- homemade traction bars-Mickey Thompson ATZ 285/75/R16
Farmer93 is offline
post #3 of 80 (permalink) Old 01-24-2013, 02:46 PM Thread Starter
05dmax89's Avatar
Wats pcv ?
Who did u order ur kit thru
2005 LLY
92 12 valve
05dmax89 is offline
post #4 of 80 (permalink) Old 01-24-2013, 02:48 PM
07GMCLBZ's Avatar
Are you gonna do a full delete or just put the blocker plate in?
07 GMC CCSB CLASSIC LBZ
EFI Live DSP5 by Duramaxtuner
SDP EGR delete, PCV Reroute
MBRP DP
4 inch MBRP straight
Isspro boost and pyro gauges
ReadyLift keys/ 1" blocks
Moto Metal 951's
285/75-16 Nitto Terra Grapplers
07GMCLBZ is offline
post #5 of 80 (permalink) Old 01-24-2013, 02:51 PM Thread Starter
05dmax89's Avatar
Full delete
2005 LLY
92 12 valve
05dmax89 is offline
post #6 of 80 (permalink) Old 01-25-2013, 09:41 AM
Rifleman3's Avatar
You could get a PCV reroute kit from Alligator. What is does is that it stops oil from getting in your turbo and pushed into your Intercooler.
Jayson
2004.5 GMC Sierra
AirDog II 165, Built Motor, DP72, Suncoast Trans EFI Live tuned by Rob at ATP
"Live by a gun,Die by a bullet"
Rifleman3 is offline
post #7 of 80 (permalink) Old 01-25-2013, 01:37 PM
DuramaxSilvy's Avatar
i never understood why to delete the pcv...you would think that the turbo would want some lubrication.
2005 4x4 2500HD LLY ECSB
Arp studs, Grade C's, 3" DP, Whats an EGR?, Fuel Filter 3/8 Spacer, ATP Autocal DSP2 80hp street/40hp tow vvt brake, 4" MBRP Turbo Back, 5" Tip ,AFE Mouthpiece, All On/Dual Park Lights, Leveled Kool-Vue Tow Mirrors, 18%Tint, debadged, Discoverer AT3's, 2006 Lower Valance, Extang Trifecta, Amsoil where ever oil should be
DuramaxSilvy is offline
post #8 of 80 (permalink) Old 01-25-2013, 01:53 PM
gr8shot's Avatar
The turbo SHAFT needs lubrication and gets it through the oil feed line. The IMPELLER only needs dry clean air. Misting oil on to the impeller has zero benefits, only detrimental affects.
Sent from my DROID RAZR using AutoGuide App
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #9 of 80 (permalink) Old 01-28-2013, 07:29 PM
bstanton's Avatar
go run a mile. then stick a straw in your mouth and try to breath. thats how your engine feels with the egr there..
11' CC/SB LTZ LML
Stock for now...
bstanton is offline
post #10 of 80 (permalink) Old 01-28-2013, 08:18 PM Thread Starter
05dmax89's Avatar
So egr delete = more power ?
2005 LLY
92 12 valve
05dmax89 is offline
