Old 04-20-2009, 10:19 PM   eBay Motors   #1 (permalink)
torkman15
torkman15's Avatar
LLY to LBZ mouthpiece screwup leads to complete EGR removal
OK I have read all the posts about this and thought I could get er done without too much heartache but NO I can't do anything without having to fix about 3 other things I tear up along the way, so if you are about to make this swap check this out. I didnt really want to grind the flange of my new LBZ mouthpiece so I read somewhere I could bend the EGR cooler bung down a little bit and your good, wrong answer I didnt bend it far at all before it would not go any further. I wanted a lil space in there even an 1/8th of an inch so I would not get any heatsoak from that cooler bung. I ended up grinding some on the mouthpiece, all is well, wrong I had cracked the edge of the cooler bung weld.
I ended up eliminating the entire EGR cooler and valve then made plates to blockoff the exhaust and take the place of the EGR valve.
All the crap I took off today...
The older I get the less I know.
2005 CCSB with a 6in RCD lift, 325 65 18s, 4.56 gears, 4in Magnaflow straight pipe and a BD CAI, Latest and greatest PPE oil centrifuge. Now I need a pass side up pipe for an LB7 and my EGR removal will be complete.
torkman15 is offline   Reply With Quote
Old 04-20-2009, 10:20 PM   eBay Motors   #2 (permalink)
timespentsearching
timespentsearching's Avatar
nice, youll be glad
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline   Reply With Quote
Old 04-20-2009, 10:30 PM   eBay Motors   #3 (permalink)
Toypuller
Thats the way to do it. forget that block off plate remove it all. Right on.
2005 LT 3500HD CCLB SRW LLY
EFI LIVE TUNED BY IDAHOROB
TCM TUNED BY MMLMM
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Mcculloch 5300k HIDS
Old 04-20-2009, 10:41 PM   eBay Motors   #4 (permalink)
torkman15
torkman15's Avatar
Yup, the truck is on a diet now, 25 pounds down 1,875 pounds to go :cool
Old 04-20-2009, 10:49 PM   eBay Motors   #5 (permalink)
Nemo
Wants Brians Rod!
Nemo's Avatar
thats a lot of chit.
-Nemo
04.5 LLY 4x4 lifted CC S/B - EFI Live
Nemo is offline   Reply With Quote
Old 04-20-2009, 10:52 PM   eBay Motors   #6 (permalink)
turbodax
turbodax's Avatar
cleanest engine bay i've ever seen....
2004.5 Duramax LLY Crew Cab 4x4
4" Turbo Back MBRP SS Offroad Series
AFE Stage II Cold Air Intake with ported mouthpiece
Edge Juice with Attitude
33" BFG All Terrains
Plugged Turbo Resonator EGR Blocker and Fingerstick
Readylift Leveling Kit with Rancho 9000 in rear
Rhino Liner
Auxiliary Battery Setup
HID Headlights
Sound System
turbodax is offline   Reply With Quote
Old 04-20-2009, 11:06 PM   eBay Motors   #7 (permalink)
mackthehack
mackthehack's Avatar
torkman15, what type of programmer are you running, to be able to remove the egr unit? I have been wanting to remove mine.
mackthehack is offline   Reply With Quote
Old 04-21-2009, 08:15 AM   eBay Motors   #8 (permalink)
torkman15
torkman15's Avatar
The short version of a long story is I've had HPTuners since I bought my first LS1 Camaro 6 years ago. Tuners has been adding different cars since then and now supports the Duramax, all I had to do was update my laptop. It looks like EFI live is headed in the same direction but started out focusing on the Duramax right away. HPTuners was all LS1/LS6 when I bought it. Both look the same as far as I've seen. Good luck to ya, Tom
Old 04-21-2009, 05:38 PM   eBay Motors   #9 (permalink)
mackthehack
Thanks for the info. This is an idotic question but, what do you need the lb7 up pipe for? Would I need one as well when I remove my egr system on my lbz? Thanks
Old 04-21-2009, 06:55 PM   eBay Motors   #10 (permalink)
Dustin88d
Needs H2 wheels
Dustin88d's Avatar
The LBZ MP wont fit on the turbo without grinding the MP?
05 Chevy, EC SB, 4x4, LLY Duramax, Allison, leveled, Eagle 079s, 285 Mastercraft CTs
Kodiak MP, S&B, 5" exhaust, Autometer GS, PPE HOT+2
Totaled... 04.5 Cummins
Dustin88d is offline   Reply With Quote
