Old 07-03-2006, 03:31 PM   eBay Motors   #11 (permalink)
claydog
claydog's Avatar
what about changing the cam? would this benefit me because ill be towing almost everyday?
claydog is offline   Reply With Quote
Old 07-03-2006, 04:21 PM   eBay Motors   #12 (permalink)
05_LLY
Hit the Pace Car?
05_LLY's Avatar
Turbo Diesels benifit very little from a cam change untill you get in to wild hp numbers, if your towing alot the best and most practical mods would be a kennedy diesel boost stick and some sort of mild tune somewhere in the 60 -90 hp range!!!!
But if your still interested in a cam i know comp was working on some and i think they are avaliable but i dont know where or how much!
Later
CAleb
Mine- 05 RC/LB D/ZF-6-Twin turbos, twin pumps, Tripple clutch
Hers-04.5 CC/SB D/A Big turbo, Big pump, Big trans
runNADM.com
EFI Live By Ricky Bobby
Old 07-03-2006, 06:04 PM   eBay Motors   #13 (permalink)
claydog
claydog's Avatar
nahh i was just asking. but now im curious about the kennedy diesel boost stick... what is it???
Old 07-03-2006, 06:21 PM   eBay Motors   #14 (permalink)
05_LLY
Hit the Pace Car?
05_LLY's Avatar
ITs just a simple device that plugs into the map sensor and fools the signal into making the turbo make more boost!
The factory boost signal is caped at 24 psi the BS (boost sitck) i beleive raises it to about 30 psi which really helps egts and still keeps boost under the no zone of 34 psi which is when the stock vvt wants to go boom!!!!!
And another benifit of the bs is it will add hp up to +30 but ona stock truck it might only add 5 or 10 but the more tuneing u add the more the bs likes it and will add more power. When i had mine i used to two with a ppe 90 hp tune and the bs with egts never foing over 1250!!!!!!
Later
Caleb
runNADM.com
