Old 05-29-2009, 05:43 PM   eBay Motors   #1 (permalink)
Chazm107
Chazm107's Avatar
Best option for boost
Hey guys i have a question about the PPE boost valve vs the setup from Kennedy Diesel, the kd setup as far as i can read is a harness assembly and the ppe is a mechanical valve, i no you wont see the benefits with out more fuel but im looking for some input from anyone that has tried either one.
05 Silverado Crew Short Bed LLY,6" superlift, 22" dubs
35" nitto Terra Grapplers AT,AFE Stage 2 W/pro guard 7
Lbz mouth piece,fuel Rail shimmed,5" Mbrp turbo back cat delete with 6" tip
Diamond eye down pipe
Autometer phantom gauges, trans go shift kit
Mag hytec deep trans pan, BD manifold, egr blocked no fingerstick
Pcv reroute,PPE standard, kennedy diesel boost stick
Chazm107 is offline   Reply With Quote
Old 05-29-2009, 06:16 PM   eBay Motors   #2 (permalink)
CaseBlackKnight
CaseBlackKnight's Avatar
Im not 100% sure but the PPE one only works on waste gated turbos - so anything after 04 it wouldnt work on. And i also believe that the computer controls the boost on all the newer engines so you would need to modify that which is why they have a "harness assembly". my .02
Kyle
02 Chevy 2500 LB7 extended cab long box
PPE Standard Tuner on +90HP, PPE Boost Valve
4" Turbo Back Straight Piped, Resonator Plugged
Autometer NV Boost and Pyrometer
B&W Turnover Ball Gooseneck Hitch
CaseBlackKnight is offline   Reply With Quote
Old 05-29-2009, 06:20 PM   eBay Motors   #3 (permalink)
SC DURAMAX 444
i have that same model truck as you and i got a ppe bosst controller. well worth the money if you dont already have a good programer that already increases boost. i almost doubled my boost. very dangerous tho if you dont have guages
SC DURAMAX 444 is offline   Reply With Quote
Old 05-29-2009, 06:40 PM   eBay Motors   #4 (permalink)
RedBowTies88
RedBowTies88's Avatar
hey just wondering ive been thinking about getting one of those...how much boost have you ran with it so far and does it make your truck sound awesome? ive heard it does this
LLY Cc/sb 4x4 RED
Originally Posted by Sean S
Originally Posted by McRat
Old 05-29-2009, 06:51 PM   eBay Motors   #5 (permalink)
SC DURAMAX 444
ive ran up to 38 psi with the knob almost turned all the way up. anymore on a stock charger and you'll be getting a new one. as far as the sound it made my turbo whistle alot more, before i got it at about 50 mph i couldnt even hear my turbo but now i can def hear it alot better. it even does this really cool little sound when you let off the throttle real fast when the turbo is charged up. shoots your smoke a little further out the exhaust too! i have found no falts with it so far tho.
Old 05-29-2009, 07:06 PM   eBay Motors   #6 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
38 psi on a stock IHI lb7 turbo? Surprised its still in one piece...
Old 05-29-2009, 07:07 PM   eBay Motors   #7 (permalink)
RedBowTies88
thats awesome thanks for the info i wanna get one but im currently saving for a trans rebuild
LLY Cc/sb 4x4 RED
Old 05-29-2009, 09:39 PM   eBay Motors   #8 (permalink)
Chazm107
Chazm107's Avatar
thanks for the information, yeah i have only herd guys running low 30's for boost to be safe on a fairly stock truck good to it might be possible to go a bit higher im going to try to keep it around 30
Old 06-01-2009, 08:02 AM   eBay Motors   #9 (permalink)
Killerbee
Killerbee's Avatar
28-30 without induction overhaul, 34-36 psi with induction overhaul. (sea level)
These represent the same shaft HP and rpm. Above this, wear is highly accelerated. If you ar higher elevation, subtract your elevation in psi, eg, for denver, subtract 2 psi.
Michael, 2500HD LLY, Systems Engineer, EMAIL
PRODUCT PAGE CUSTOM TUNING
Quick Links:ECM's , INDUCTION OVERHAUL, EFILive,
NEW Lockable DSP Switches coming DEC 1
Old 06-01-2009, 09:41 AM   eBay Motors   #10 (permalink)
RedBowTies88
Pardon me killerbee but what is induction overhaul?
LLY Cc/sb 4x4 RED
