| Fuel System Upgrades Ive been reading on all the past threads about lift pump options and im pretty set on the TTS setup, my question about the ported fuel rail fittings, is reason to change it or only neccesary for big tunes or just to improve flow? i would just need one fitting correct? i see ppr sells them for about $35
__________________ 05 Silverado Crew Short Bed LLY,6" superlift, 22" dubs
35" nitto Terra Grapplers AT,AFE Stage 2 W/pro guard 7
Lbz mouth piece,fuel Rail shimmed,5" Mbrp turbo back cat delete with 6" tip
Diamond eye down pipe
Autometer phantom gauges, trans go shift kit
Mag hytec deep trans pan, BD manifold, egr blocked no fingerstick
Pcv reroute,PPE standard, kennedy diesel boost stick |
