Old 06-07-2009, 02:38 PM   eBay Motors   #1 (permalink)
DieselRacer75
duramax junkie
DieselRacer75's Avatar
two airfilters????
hey guys its justin i got a quick question? what if instead of plugging the air resonator(the thing with 6.6 duramax printed on it under your hood) you get you a little air filter and put on it??? i got curious today and took it off and drove around and it seemed the turbo lit quicker and a massive cut down on soot like alot ill get some pics up for you guys here later
thanks justin
RANDALL - 96 12 valve CUMMINS 4x4, DDP 150's, HTT 64/71/13 turbo, AFE cold air intake ATS exhaust manifold, Dragon Fly pump 4kgs, Full cut DV's, +60 Springs, custom fuel plate, star wheel cranked, plate and AFC housing fwd, suncoast tranny, lock in override switch, triple lock converter, 4 inch exhaust into a black 6'' miter, 52 psi boost.... Oh and NO smoke switch.
JUSTIN - 05 D-MAX 4x4 EFILivetuned by MMLMM, PPE fuel valve, 4in. straight pipe Glow Shift gauges,S&B INTAKE
For all your EFILive wants and needs contact MMLMM
www.mmdieselperformance.com
DieselRacer75 is offline   Reply With Quote
Old 06-07-2009, 02:56 PM   eBay Motors   #2 (permalink)
dmaxxpower
dmaxxpower's Avatar
you would bypass the MAF if you did that, allowing more air than expected into the engine.
-Stephen-
06 Chevy LBZ
EFI Live thanks Mike-MM Diesel Performance
www.huskerdiesel.com
dmaxxpower is offline   Reply With Quote
Old 06-07-2009, 03:00 PM   eBay Motors   #3 (permalink)
DieselRacer75
duramax junkie
would that mean a code would be thrown? i drove mine for about thirty minutes and it ran alot more responsive and seemed more powerful
Old 06-07-2009, 03:42 PM   eBay Motors   #4 (permalink)
DuraTitus
DuraTitus's Avatar
That sounds great Would it cause a problem?
Pickup: 2002 Chevrolet 2500HD Duramax/Allison Reg. Cab with
Royal Utility bed and racks
Intake: Stock with KN Filter
Transmission: Stock
Mileage: 151,000 No Rust
DuraTitus is offline   Reply With Quote
Old 06-07-2009, 03:53 PM   eBay Motors   #5 (permalink)
delong_1
truck for sale
delong_1's Avatar
there is no reason to bypass the maf, if you want more flow do the airbox mod or just pull the box and put a filter on it, or of course get an intake.
Nate
2 turbos, built trans, and some tuning.
Old 06-07-2009, 04:50 PM   eBay Motors   #6 (permalink)
gr8shot
LMM'N
gr8shot's Avatar
Honestly its a terrible idea to do that. Did you put a filter over the resonator opening before you went driving around? If not, then you just sucked a whole bunch of dirt and dust into your engine and through your turbo, which is NOT good.
There are a couple reasons its a TERRIBLE idea. First is that it will throw off the a/f ratio, since less air will be going by the MAF sensor the computer will not send as much fuel as it should, which actually means you'll probably make less power than you should.
The second reason is that you'll be sucking in HOT HOT HOT air. Heat is the enemy of a turbocharger. Compressing the air heats it greatly, and when you compress already hot air, then the intercooler can't cool it enough before it gets to the engine, and you get a hot charge of air, which is virtually useless to the motor. End result is less complete combustion, higher EGT's, and loss of power.
I can't stress enough how bad of an idea this is. Either plug the resonator, or put it back on. DO NOT leave it open, even with a filter on it. Nothing good can come from it.
Jesse Meyers | Husker Diesel | 402-570-1200
Blocker Plates | WIF Wrench | Fuel Filters
www.huskerdiesel.com | Email us!
Visa, MasterCard, Discover, American Express, PayPal
* GIVE US A CALL FOR THE BEST DEALS! *
Old 06-07-2009, 04:53 PM   eBay Motors   #7 (permalink)
delong_1
truck for sale
delong_1's Avatar
its not a gasser, we dont need a certain amt of air or fuel. more is better, both fuel and air. but you are right that would pull in about the hottest air.
Nate
Old 06-07-2009, 05:44 PM   eBay Motors   #8 (permalink)
usafracer
Red trucks rule.
usafracer's Avatar
Your right we dont need a certian amount of air or fuel but the engine does need to know what it is getting.
2008 GMC Sierra Crew Cab 4X4
2004 CC/SB 4X4 Duramax (sold)
Old 06-07-2009, 05:56 PM   eBay Motors   #9 (permalink)
DieselRacer75
duramax junkie
ok thanks for the input guys i was just curious on the idea
Old 06-07-2009, 06:02 PM   eBay Motors   #10 (permalink)
HumboldtDmax
Obama stole my rims
HumboldtDmax's Avatar
because its closer to the turbo its going to try to suck most of the air through that little filter until theres enough resistance to pull it though the main filter. I'm sure it going to get dirty very quick and I'll bet doesnt filter as well as the main
7.5 LMM CHEVY CC LT Z71 white
Fab Four front bumper, lots of Line-X
Rancho 4in w/Bilstiens, HD tie rods and braces
35x12.5 Toyo MT on 20x10x4.5BS KMC Monsters in black
[BANKS intake,dual exhaust,intercooler]straight piped
BD manifold,Fitch fuel catalyst,res mod,EGR delete
AFE turbo tube, PPE race fuel valve
EFI live, Edge Insight
AD150 & SC4 collecting dust in the shop
HumboldtDmax is offline   Reply With Quote
