Old 06-17-2009, 04:54 PM   eBay Motors   #1 (permalink)
Chazm107
Chazm107's Avatar
Boost numbers
Just installed my gauges yesterday boost and pyro, what kind of boost are you guys seeing, at w.o.t my truck is holding 27psi, whit kind of numbers are u guys getting
05 Silverado Crew Short Bed LLY,6" superlift, 22" dubs
35" nitto Terra Grapplers AT,AFE Stage 2 W/pro guard 7
Lbz mouth piece,fuel Rail shimmed,5" Mbrp turbo back cat delete with 6" tip
Diamond eye down pipe
Autometer phantom gauges, trans go shift kit
Mag hytec deep trans pan, BD manifold, egr blocked no fingerstick
Pcv reroute,PPE standard, kennedy diesel boost stick
Chazm107 is offline   Reply With Quote
Old 06-17-2009, 04:59 PM   eBay Motors   #2 (permalink)
usafracer
Red trucks rule.
usafracer's Avatar
I am around 35 with my LMM and about 32 with the LLY at work both have EFI live on them.
2008 GMC Sierra Crew Cab 4X4
2004 CC/SB 4X4 Duramax (sold)
Old 06-17-2009, 05:04 PM   eBay Motors   #3 (permalink)
DuraTitus
DuraTitus's Avatar
29-30 max
Pickup: 2002 Chevrolet 2500HD Duramax/Allison Reg. Cab with
Royal Utility bed and racks
Intake: Stock with KN Filter
Transmission: Stock
Mileage: 151,000 No Rust
DuraTitus is offline   Reply With Quote
Old 06-22-2009, 09:02 AM   eBay Motors   #4 (permalink)
Killerbee
Killerbee's Avatar
if you don't have tuning, this is too high. But it depends on where you have your sensor tapped and whether you have a correct install, or subject to ram influence.
Michael, 2500HD LLY, Systems Engineer, EMAIL
PRODUCT PAGE CUSTOM TUNING
Quick Links:ECM's , INDUCTION OVERHAUL, EFILive,
NEW Lockable DSP Switches coming DEC 1
Old 06-22-2009, 09:24 AM   eBay Motors   #5 (permalink)
Chazm107
Chazm107's Avatar
killerbee my truck has no tuning or programming done to it just the upgrades listed in my signature, i have the boost gauge connected to the boost tube coming right off the turbo, after playing around a bit more it still hits 27psi but comes down after hitting 3rd 4th 5th gear could you please give me an idea of what it should be
Old 06-22-2009, 10:33 AM   eBay Motors   #6 (permalink)
Killerbee
Killerbee's Avatar
stock boost at the MAP sensor should be around 20 psi if you are low elevation. Add 2-4 psi for losses upstream to your sensor, and you are probably in the ballpark.
I assume that your number goes up a little with increased rpm?
Old 06-22-2009, 11:23 AM   eBay Motors   #7 (permalink)
chevymakesitizuzushakesit
chevymakesitizuzushakesit's Avatar
i hit no mre then 26
05' CCSB 4x4 DMAX/Allison
mbrp, ppe, airdog, nitto, efi live, autometer, bilstein
chevymakesitizuzushakesit is offline   Reply With Quote
Old 06-22-2009, 12:39 PM   eBay Motors   #8 (permalink)
EastCoastGoose
EastCoastGoose's Avatar
30 is the highest i've seen
-Tyler
2005 GMC LLY Farm Truck
Runs 13's and my hot girlfriend likes F*rds .....
EFI/DSP5 tuned by Rob and Nick
And some other goodies
EastCoastGoose is offline   Reply With Quote
Old 06-22-2009, 01:15 PM   eBay Motors   #9 (permalink)
Killerbee
Killerbee's Avatar
Boost discussions are like mpg threads.
Everyone has a different arrangement, tuning, sensor location, MAP vs boost confusion, etc
Old 06-22-2009, 02:27 PM   eBay Motors   #10 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
i have seen 40PSI ..yep its a stock LLY turbo but if i'm not mistaken it didnt like it to well but it still lives!
from my memory our LLY on stock tuning would hold roughly 23-24PSI and spike 25PSi at times..reading taken from the cold side of the intercooler just before the intake!
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
