Old 06-29-2009, 07:52 PM   eBay Motors   #1 (permalink)
SzymoDmax
SzymoDmax's Avatar
dsp 5 inst???
i got my efi live today but i can't find any info on how to install the dsp 5 switch. if anyone could help me out that would be great. thanks in advace Dustin
2004 chevy 2500hd with lly
efi live & dps 5 switch tuned by idahorob
mbrp straight piped 4"duals 6" tips
egr blocker plate, lbz mouth piece
06, grill and hood, sunroof and many more
Moto Metal 950 wheels with 285/75/16 BFG'S
Truck#2 1983 chevy 4x4 with 5.9 12 valve
Let men marry men and women marry woman...in 3 more generations there will be no more democrates
SzymoDmax is offline   Reply With Quote
Old 06-29-2009, 07:56 PM   eBay Motors   #2 (permalink)
nwtdiesel
<< my new tie rods ;)
nwtdiesel's Avatar
What exactly do you need help with? They are pretty easy to do.
04 Dmax 753rwhp #2 only Las Vegas, NV 8-27-09 (old heads)/11.8@117 #2 only full street trim on 22"s Albuquerque, NM 5200ft elevation
NWTDiesel's truck is NASTY. Blacked out miles of road down I25 and beat up on 505Outlawz 11.5 car from a roll. I was trying to keep up but my Cummins is slow
Good times lastnight. That truck is fast as snot and I knew that I would get walked but I still wanted to try.
Joe
03 SVT Lightning
nwtdiesel is offline   Reply With Quote
Old 06-29-2009, 08:01 PM   eBay Motors   #3 (permalink)
nwtdiesel
nwtdiesel's Avatar
The pins for a LLY are # 32 and #50.
Joe
03 SVT Lightning
Old 06-29-2009, 08:06 PM   eBay Motors   #4 (permalink)
SzymoDmax
SzymoDmax's Avatar
ya, just curious what pins to use, you don't have a pict do you or wire colors?
Old 06-29-2009, 08:13 PM   eBay Motors   #5 (permalink)
LarryJewell
Post Whore in Training
LarryJewell's Avatar
open any efi tune and go to the help tab, then tutorials, then dsp tutorial, it will bring up a manuel with color pics and instructions for hooking up the switch and also how to convert a single tune to dsp format.
04 LLY 2WD
Efi Live
Suncoast Stage III
71.5mm Cheetah
Banks LBZ Intake
MBRP, Diamond Eye & BD exhaust
PPE Egr delete
PCV re-route
FASS 150/150
Cal-Trac's
LarryJewell is offline   Reply With Quote
Old 06-29-2009, 08:15 PM   eBay Motors   #6 (permalink)
nwtdiesel
nwtdiesel's Avatar
Take your ecm out and out of the way.
Clean the back of the wire connectors real good. You will see the numbers by where the wire goes into the connectors.
You have to pop the black plastic cover off of them and pull the blue slide pin out to get to where you can put your wire in. After you get your wire in, slide the blue plastic piece back in and snap the black plastic cover on. Throw a couple zip ties around it to help secure. Put the ECM harness back in and flip the grey tap closed.
Joe
03 SVT Lightning
Old 06-29-2009, 08:16 PM   eBay Motors   #7 (permalink)
nwtdiesel
nwtdiesel's Avatar
x2
Do some reading for a bit.
Joe
03 SVT Lightning
Old 06-29-2009, 08:18 PM   eBay Motors   #8 (permalink)
SzymoDmax
SzymoDmax's Avatar
thanks guys, i was having a hard time finding any info, thanks a lot guys
Old 06-29-2009, 08:22 PM   eBay Motors   #9 (permalink)
nwtdiesel
nwtdiesel's Avatar
Anytime.
PM me if you need anymore help.
Joe
03 SVT Lightning
Old 06-29-2009, 11:02 PM   eBay Motors   #10 (permalink)
chevymakesitizuzushakesit
chevymakesitizuzushakesit's Avatar
ps dont brake any thing in there it expensive i know green clip or the pins make sure there stright not cheap to replace
05' CCSB 4x4 DMAX/Allison
mbrp, ppe, airdog, nitto, efi live, autometer, bilstein
chevymakesitizuzushakesit is offline   Reply With Quote
