Old 07-01-2009, 08:57 PM   eBay Motors   #1 (permalink)
rdohara
EGR Removal
I have the PPE plate and black box that fools the factory ECM can i remove the whole EGR system with this PPE Kit??
rdohara is online now   Reply With Quote
Old 07-01-2009, 09:03 PM   eBay Motors   #2 (permalink)
K9Duramax
K9Duramax's Avatar
no, this is just the block off kit with the fingerstick- fingerstick may not be needed, what year is your truck. Fill out your sig. so we know...
'05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Synthetic Motorsports
http://lb7.info/
K9Duramax is offline   Reply With Quote
Old 07-01-2009, 09:31 PM   eBay Motors   #3 (permalink)
Hondarider552
AZ Dyno Day Nov. 7th
Hondarider552's Avatar
No, the egr block off plate is too thin to hold back 35+ psi of drive pressure.
What year truck do you have?
Brian
06 LBZ
Slightly tuned
20" monsters on 285's
Lowered
Magnaflow
HTT 66/71
Tuned by MMLMM
www.mmdieselperformance.com
11.99 is 1 second faster than 12.0
Old 07-02-2009, 01:40 PM   eBay Motors   #4 (permalink)
rdohara
i think you all missunderstood me i just want to know if the PPE black box will make the ECM think that the EGR is still there if i remove the whole EGR system or it will mess it up I know that i will need to make thicker plates if i remove the whole EGR
Old 07-02-2009, 01:49 PM   eBay Motors   #5 (permalink)
Hondarider552
Fill out your sig that will help us help you.
Brian
06 LBZ
Slightly tuned
Lowered
Magnaflow
HTT 66/71
Tuned by MMLMM
Old 07-02-2009, 01:49 PM   eBay Motors   #6 (permalink)
MMLMM
Tuning, Tuning, Tuning...
MMLMM's Avatar
as long as it shuts the egr operation off and blocks codes. You will need to plate off the up pipe, plate off the intake runner over the egr, and splice the egr coolant line together. You also need to support the intake runner some how as the egr valve body supports it.
Custom Duramax Tuning
EFI Live Sales & Support
Click Here - LMM DPF Delete Package - Click Here
MMLMM is offline   Reply With Quote
Old 07-02-2009, 01:53 PM   eBay Motors   #7 (permalink)
RedBowTies88
RedBowTies88's Avatar
hey mike whats the bennies from taking the whole thing out as opposed to just blocking it?
Cc/sb LLY 4x4, aerodynamic passenger door dent mod, 6-gun/SL and SC flashpaq, egr blocked, factory 3 1/2 straight piped, banks ram air, home made spring clamps, sleeves and braces, msd dual lazer gauge. Trutrac Diff. NEW BEST TIME... 14.140 at 94.69 still using 2WD
Very hurt tranny
Old 07-02-2009, 01:53 PM   eBay Motors   #8 (permalink)
1lowdiesel
1lowdiesel's Avatar
do you have a programmer on the truck now?
05 PPE hot, Quadzilla Adrenaline, BD manifold, PPE boost controller, Shimmed rail, Airdog 150, Egr delete, Volant front pipe, AEM / Airaid intake 6" black stack no muffler no "kitty", custom mouthpiece, custom air ride cantilever 4-link suspension, 22" Raceline CR2s, DJM upper and lower control arms, McGaughy's spindles.
1lowdiesel is offline   Reply With Quote
Old 07-02-2009, 02:00 PM   eBay Motors   #9 (permalink)
MMLMM
MMLMM's Avatar
weight, flow restriction, better looking. why have parts under hood you dont even have working.
Old 07-02-2009, 03:42 PM   eBay Motors   #10 (permalink)
AlligatorPerformance
AlligatorPerformance's Avatar
The PPE code blocker will not stop that codes with removal of the EGR. The motor has to be plugged in for the code blocker to work. You will need a PPE standard (or up) or EFILive.
Alligator Diesel Performance - Chad Hall Owner 1-866-255-7212
AlligatorPerformance is offline   Reply With Quote
