Old 11-04-2007, 09:02 PM   eBay Motors   #1 (permalink)
D2THAMAX
D2THAMAX's Avatar
Head studs
I was wondering how hard it it is to install head studs. do you have to take the head off or can you just take one bolt out at a time and exchange it with the stud? Thinkin about the gt40 turbo kit from ppe
2005 WHITE DMAX/ALLI CREW CAB SHORT BED, AUTOMETER C2 PYRO BOOST AND FUEL PRESSURE, AFE STAGE 2 INTAKE, SILVERLINE DUAL 4 INCH STRAIGHT PIPES, DIAMOND EYE TRUE DOWN PIPE, BLOCKED EGR, EFI LIVE, FLEECE PERFORMANCE 70MM CHEETAH TURBO, ATS EXTREME TRANS 5 STAR TC and COPILOT. SUNCOAST T CASE BRACE, BD BLOW OFF VALVE , FULL BORE MANIFOLD, COOL DOWN TIMER, TTS DUAL LIFT PUMPS, PPE RACE VALVE, FABTECH HD TIERODS,CALTRACS COGNITO BRACES, T BARS LOWERED, 20INCH ICE METALS WRAPPED WITH 305 50 TOYO PROXES.
D2THAMAX is offline   Reply With Quote
Old 11-05-2007, 03:38 PM   eBay Motors   #2 (permalink)
duramaxin14
duramaxin14's Avatar
Head studs are not hard just very time consumming. U can take 1 bolt out at a time but if i was u before i done the gt40 i would deffantly look into some rods and pistion. And why your that far down put a cam in the truck. It will cost u about 7500 dollars to do all this which is cheaper then about 15000. Just my .02
Snow flake 2004.5 D/A Efi live, PPE lift pump, 35inch mudders and a florida stack
13.20@115 mph
duramaxin14 is offline   Reply With Quote
Old 11-05-2007, 08:42 PM   eBay Motors   #3 (permalink)
D2THAMAX
D2THAMAX's Avatar
Do you do anything with the block or just put the hd rods and new pistons and rings in. Who would you reccomend to do that engine work?
Old 11-06-2007, 02:43 PM   eBay Motors   #4 (permalink)
duramaxin14
Duramaxs dont like no more then 600 hp on stock bottom ends. The heat from timing and cyl pressure from larger turbos take a toll on these motors after 600 hp. Usally u may be fine with a large single keep the timing down and do not run dual fullers. But why take that risk. If u have anymore questions fill free to Pm me. We can talk there or i can give u my Number
Kurt
13.20@115 mph
Old 11-12-2007, 05:25 PM   eBay Motors   #5 (permalink)
duramaxin14
Hey buddy did u figure out what route u where going to take on this. Are u going to just do the head work. Or the whole bottom end??
Kurt
13.20@115 mph
Old 11-12-2007, 08:21 PM   eBay Motors   #6 (permalink)
D2THAMAX
D2THAMAX's Avatar
I decided to do the whole bottom end. im just going to do it right the first time around. im going to go with the socal diesel internals. and the gt4094 turbo Im going to start the build after the holidays forsure by mid jan
mike
Old 11-15-2007, 12:36 AM   eBay Motors   #7 (permalink)
Diesel Nut
Right on. Should be fun. ARP makes stud kits for the bottom end on these trucks.
Diesel Nut is offline   Reply With Quote
Old 11-15-2007, 07:47 PM   eBay Motors   #8 (permalink)
D2THAMAX
D2THAMAX's Avatar
Definatly will be fun. and thats a big yes on the arp main studs
