| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 04.5-05 LLY Performance Parts Discussion Discussion of Performance Parts For the 04.5-05 LLY Duramax Trucks No Advertising |  | |
11-06-2007, 06:08 PM
eBay Motors
#1 (permalink)
| | Junior Member
| Help  OK I have a question. Let me set the premise first. I have the following on my 2005 lly
1) 4” exhaust
2) Edge w/ Attitude
3) Airaid Intake
My questions or problem is I tow a travel trailer about 8000 to 9000. Every time I tow (in any level 1-3) even on flat highways my GET go trough the roof to over 1300 quickly and then my truck goes into limp mode and the check engine light goes on and I have to pull over. It is frustrating OK I have a question. Let me set the premise first. I have the following on my 2005 lly
1) 4” exhaust
2) Edge w/ Attitude
3) Airaid Intake
My questions or problem is I tow a travel trailer about 8000 to 9000. Every time I tow (in any level 1-3) even on flat highways my GET go trough the roof to over 1300 quickly and then my truck goes into limp mode and the check engine light goes on and I have to pull over. It is frustrating because I have spoken to other people with the exact truck who do not have this issue. Any advice on what I should be looking at or doing differently
Thanks Chris |
| Advertisement
11-06-2007, 06:24 PM
eBay Motors
#2 (permalink)
| | Hi, I'm Earth. Have we met?
| Fuel filter been changed latley?
__________________ Caleb Mine~05 D/ZF Reg. Cab D-Max/ZF-6 big mouth peice, bored out stock turbo, shimmed auto zone clutch, bright headlights, rebar trac bars 11.82 @ 118.4mph~~ 698.8HP "Outa time" Hers~04.5 D/A CC/SB- bored out mouth peice, hogged out stock turbo, Sr kit trans, hot fuel additive, rebar traction bars/ 2.6 Puller "Girls Night Out" Buy it cheap, buy it twice! |
11-07-2007, 06:30 AM
eBay Motors
#3 (permalink)
| | Hang on tight!
| Maybe I'm wrong...but when towing...if you don't have an aftermaket kit on your tranny...and you are running a tune....I don't really think it's good for your stock tranny. That's probably why you are going into Limp-home mode. And everytime you Limp it...it gets easier and easier. Plus when you are towing that much...it strains your engine, making it work harder, therefore EGT's will be higher....with added HP...your EGT's will be even higher. Try putting the truck to stock and towing that way...see what your EGT's are then and see if your tranny limps. If you tranny limps stock...you might need to do a rebuild. If your EGT's are high...like 05_LLY said...check the fuel filter and fluids..make sure all openings are clear.
__________________ RIDE: 2007 Chevy CC LBZ / 6 speed LIFT: Ready Lift Leveling Kit TRANS: Big Dipper Stage IV/PPE Deep Pan SOUND:Touchscreen Pioneer P4000DVD/Backup Camera - 6 1/2 Polk Audio everywhere else. ADD ONS: AD II 165, IronBull Bumper, Cowl Hood, 5K/3K HIDs, Dominator II Steps, BFXenon Grill, ExTang Solid Fold TIRES/WHEELS: 35X12.50-17 Nitto Trail MTs on 17x9 Liquid Metal Gatlins, HD Sleeves AIRFLOW: BANKS Monster Dual S-Piped, EGR blocked, and Banks Ram Air PROGRAMMERS: EFI live DSP5 |
11-07-2007, 01:43 PM
eBay Motors
#4 (permalink)
| | DuramaxForum Fanatic
| The code u are getting is p1093 call ppe order the shim kit put it in the truck and no more 1093 code.
__________________ Snow flake 2004.5 D/A Efi live, PPE lift pump, 35inch mudders and a florida stack
13.20@115 mph
I am sorry that i can not make it to threads in times. If u are having a problem and need help pm me and i will get to u ASAP |
11-08-2007, 05:15 AM
eBay Motors
#5 (permalink)
| | Diesel Addict
| do you get a 2K rpm gov when it goes into limp mode?if so it could be a couple of things,for starters a weak Fuel Rail valve(or something like that)or the Fuel Regulator is going bad and you can tow with the Edge installed but that still doesn't explain the high EGT's,try uninstalling the Edge and see what happens..just some thoughts
__________________ James
Priority List
God
Wife
Her Car
Work Car
then the Truck |
11-11-2007, 05:12 PM
eBay Motors
#6 (permalink)
| | Junior Member
| Thanks guy's, just to answer a few questions. I have changed the fuel filter twice and have tried to use additives. As for the limp mode, it does put a 2000-rpm gov on the truck. I have towed on stock no problems. I have uninstalled the Edge and I have hade no problems. Shouldn’t I be able to tow with the Edge?
I have a few questions what is a shim kit. What should I expect from an aftermarket fuel pump? |
11-12-2007, 05:50 AM
eBay Motors
#8 (permalink)
| | Diesel Addict
| my advice is sell the Edge and buy a Diablo or a PPE and don't look back..a lift pump will helps for better fuel flow but not really necessary in your case..i would do the EGR block plate and if you go to all the trouble of doing a shim kit do the race vavle right away(same diff.)i did it on my Duramax's and i never lost fuel economy but i do have better fuel flow but then again i'm runnin more HP then you are..
the Edge has been known to cause problems
Priority List
God
Wife
Her Car
Work Car
then the Truck |
11-12-2007, 07:12 PM
eBay Motors
#9 (permalink)
| | Factory Trans Pimp
Amen.
__________________ John
05' Dmax LLY CC SB, 6in. lift
PPE hot, airdog 150 and some other stuff
06' Pontiac GTO 6.0L |
11-12-2007, 10:11 PM
eBay Motors
#10 (permalink)
| | Junior Member
| OK if I put a shim kit on and sell the Edge
What is the next best programmer? I use the truck for towing (mostly) |
