Oil Coolers?? - Chevy and GMC Duramax Diesel Forum
post #1 of 6 (permalink) Old 08-21-2009, 04:53 PM Thread Starter
Oil Coolers??
Anyone run a oil cooler for the Engine oil. I have seen killerbee's oil cooler kit very nice but very $$$$$$$.
05 2500HD LLY, Banks Power PDA W/Speed Loader, Banks Intercooler, Banks Ram Air, Diamond Eye 4" Turbo Down Pipe, Banks 4" Exahust with Cat Delete, BD Manifold,LBZ MP, RDL Up Pipes, Custom EGR Delete Manifold Pipe,PVC kit,6000k HID,
EGR Removed (EFI Live for EGR Delete), Fluidamper, PWR Trans & Oil Coolers, ATS 5 Star Converter, Trans Go Shift Kit
$25k Worth of Custom Long Travel Suspension
14" In the front 18" of Travel in the Rear, King Bypass Shocks and bump stops on all 4 Corners, Walker Evens Real Bead Locks on 37" Goodyears, Complete Box frame And a whole sh!t Load of other Suspension and frame bracing
rdohara is offline
post #2 of 6 (permalink) Old 08-21-2009, 05:53 PM
Iceman56's Avatar
Same here KB's looks sweet but not for that price
White 11 Denali LML CCSB
20X9 BMF Novakanes 285 BFG's
Iceman56 is offline
post #3 of 6 (permalink) Old 08-21-2009, 06:11 PM
Banned
id run one, but not for the price Michael wants for it, its not made out of gold.
that, and having no oil pressure for like 20 seconds after a oil change steeres me away from the whole idea.
Hondarider552 is offline
post #4 of 6 (permalink) Old 08-21-2009, 06:16 PM Thread Starter
you can put a temp switch in the line that does not let the oil flow into the cooler till the oil get to about 180 degrees so that will not happen Also the oil should go from the pan to the engine then into the oil cooler so again that would not happen so you should still have the idea because i just fixed your problem hahahaha
rdohara is offline
post #5 of 6 (permalink) Old 08-21-2009, 06:27 PM
Banned
Very true, I didnt think about that..
still way overpriced "engineered" oil cooler.
post #6 of 6 (permalink) Old 08-21-2009, 10:42 PM
1953drtelco's Avatar
I read some information regarding oil cooler at another site. Some truck owners were using Generic oil coolers from Summit Racing....Less than $300.00
SummitRacing.com
2005 HD2500 Silverado 2WD EC LB (FE9 - Federal Emissions) 115K miles Goodyear Wranglers 265/70R/17,
LBZ mouthpiece upgrade, BD Exhaust, MBRP DP, Banks Ram-Air with SuperScoop ,4" SS Corsa Exhaust System w/gutted kitty, Amsoil Dual Oil Bypass Filtration, Aux Radiator (Engineer 837) installed, Firestone Air Bags, Allison extra capacity Tranny pan, MagHytec Rear Diff Cover, Synthetic Fluids ...Mike L tranny cooler) 2008 Towing Mirrors with Leveling MOD, PCV reroute, Fumoto Valve, Mad Jacks fuel fiter access door. Running 2% BioDiesel with Optilube XPD,TTS dual lift pumps with Nictane Aux Fuel Filtration. EFI (Tuned ECM from Duramaxtuner) Edge Insight CTS to control the tunes
And the best part of all, no payments and title in hand
1953drtelco is offline
