Since i installed the xcellerator if i really get after it the truck seems like its not shifting when it should. I have it set on level 3 and it don't feel like the tranny is slipping but it bumps the rev limiter for a split second before it shifts. Is this normal with the extra power?
__________________ KYLE
2010 Camaro SS LS3 426 HP
how many miles has it been since you downloaded the tune and i do know my Allison shifts nicer once i had a 100 miles or so on a tune..
__________________ James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Up to level three the Xcelerator will defuel for shifts which might explain the problem. Since you have the bullydog shift enhancer you might try reprogramming the truck on level 4 and see if that makes any difference. I have had mine on for about a month and my tranny acts a little weird when shifting under full throttle also. Probably just too much power for it. Just some thoughts.
__________________ John
05' Dmax LLY CC SB, 6in. lift
Some engine goodies
06' Pontiac GTO 6.0L
I have only put about 75 miles on it. It shifts smooth. It just feels like it's not trying to shift until it is too late. Goes into the next gear grabs and starts pulling again just fine.
Thanks for the help guys
It's defueling. Mine does it and mine's been in mine for 6 months. Just watch the 4-5 shift.
__________________ 2006 Crew Cab SB 4x4, Stock LBZ, Black with Gray leather, Factory Steps. Black H2's with 295/70/17 Nitto Terra Grapplers, Magnaflow 5" SS turbo back, Diamond Eye Downpipe, SCIV and 1058, SC Case Brace, 68mm Cheetah, EFI Live, Air Dog 150 II, Auto meter gauges and pod, EGR Blocker and FRPV shim kit, ATS dual CP3 kit, 60% Extrude hone injectors E-locker
my LBZ runnin the big tune and it doesn't do that allthough it does defuel between shifts but it doesn't jump RPM's at shift points but if i remeber right back when the our LLY had the stock tranny it did something like that and it ran like that for almost 40K miles.
Business Truck
DD/Beat Around
Economy Saver
