Old 10-15-2009, 09:49 PM   eBay Motors   #1 (permalink)
Dmax87
blown headgasket signs
My low coolant light came on so i added coolant and the next day i smell coolant and the low cooland mess came on again i open the coolant lid and can see bubbles is this a blown headgasket? please say no
Dmax87 is offline   Reply With Quote
Old 10-15-2009, 10:21 PM   eBay Motors   #2 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
depends.
Run your truck for a day, come home, pop hood, and let it sit for 4 hours. After 4 hours, go to your truck, and feel your upper radiator hose. If it is rock hard, that a sign because your heads are lifting and pressurizing your cooling system.
Old 10-18-2009, 10:11 PM   eBay Motors   #3 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
Did you check your oil? If it is the head gaskets it will put collant in the oil. That WILL make your motor lock up. If its that the oil will look like a chocolate milk shake.
However, you should smell coolant if its doing that. Id take it to a shop and have them pressure test it to see where the leak is
Jason
Old 10-18-2009, 10:25 PM   eBay Motors   #4 (permalink)
hvy_chevy_one
hvy_chevy_one's Avatar
my stupid light keeps coming on also..i add it and about 3weeks later it comes back on
2002 Black GMC 2500HD crew cab LB7.
PPE Standard turned down to 160 (poor tranny)
PPE Boost valve
Straight piped, 4inch tip.
Airaid Intake
Speedliner
T-bars turned up 4 turns
H2 rims with BFG A/T 285's
Optima Red top
Blacked out taillights, third break light, and bottom marker lights
In-Dash DVD
hvy_chevy_one is offline   Reply With Quote
Old 10-18-2009, 11:40 PM   eBay Motors   #5 (permalink)
Toypuller
Originally Posted by Hondarider552 View Post
depends.
thats how I do it at work. GM has all these stupid great little test they want us to use. Why when if you do exactly what he said to do you will know. I have never taken one apart and the gaskets wernt blown after doing this.
2005 LT 3500HD CCLB SRW LLY
EFI LIVE TUNED BY IDAHOROB
TCM TUNED BY MMLMM
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Mcculloch 5300k HIDS
Old 10-18-2009, 11:50 PM   eBay Motors   #6 (permalink)
my3rdforddied2
2006hd
I need tips from you specialist out there about how to test drive a truck that i am thinking of buying. I looked at it Saturday. The Oil Pressure guage is showing from 25 to 30 lbs when sitting idling and it goes up to 60 plus at 2000 rpms. Is this normal? And what are some other ways I can check this truck out before I pass the cash? It has 151,003 miles on it.
my3rdforddied2 is offline   Reply With Quote
Old 10-19-2009, 12:03 AM   eBay Motors   #7 (permalink)
Hondarider552
seriously??...
Old 10-19-2009, 12:24 AM   eBay Motors   #8 (permalink)
my3rdforddied2
nothing but respect for the techmechs
Hello Hondarider552, I see that you are a tech. I sure dont want to impose upon yalls conversation but if you have a little extra time this morning and if you know some tips for checking out a 2006HD with 151,003 miles on it in regard to buying it I would be so thankful sir. The oil pressure guage is apprx 25 to 30 idling and sitting at 60 at 2000rpms. I have a 2008 Ford F350/6.4powerplant in the shop with a locked up engine and the oil pressure guage always showed 40 plus idling on it.
Old 10-19-2009, 01:15 AM   eBay Motors   #9 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
Yup thats normal for these trucks. Thats when mine runs at with 30,000 miles. What are they asking for the truck? IMO a 06 with that many miles should go for around $18,000 miles.
Jason
Old 10-19-2009, 05:11 AM   eBay Motors   #10 (permalink)
ob_1jr
another red name!!!
ob_1jr's Avatar
Check your waterpump. Mine would leak and not even hit the ground when parked.
