unplug MAF sensor and watch her smoke....then break down becasue your idiots!
__________________ Vehicle 2008 Black Chevy Crew Cab Short Bed Z71 Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck Drivetrain LMM Duramax, Allsion 1000 Transmssion Performance ModsEFI Live and DSP 5 By MMLMM, RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC Other Mods B&W Turn Over Ball, Air Lift Bags, Titan 52gal fuel tank, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
dont do it in my opinion but im thinkin your talkin about the 05 in your sig so you can be like your cummins buddie if you have efilive get a dsp switch build another tune take away boost turn fuel way up adjust your sensor max limits and then just and swap tunes when you feel the need 2 smoke someone out but really its not the brightest thing....
no i wasnt wanting to do it i was curious on if it existed ive heard about it and i was seeing wat are the cons of it... my truck doesnt reaaly have trouble smokin and dsp is on the way btw
__________________ 1996 12 valve Cummins 4x4, DDP 150's, ARP 12mm head studs, Mag-Hytec DD tranny pan, AFE cold air intake ATS exhaust manifold, Dragon Fly pump 4kgs, Full cut DV's, +60 Springs, custom fuel plate, star wheel cranked, plate and AFC housing fwd, suncoast tranny, lock in override switch, triple lock converter, black 6'' miter.
__________________ 09 white on black CC/SB LTZ loaded.
RPB grill, 6k HIDs hi/low and fogs, pyro/boost gauges, 7-9" cognito, air bags w/compressor, train horns, 20" rockstars, 35" toyo MTs, 5% tint, AMP steps, DPF DELETE, 5" magnaflow w/ RPB tip all gone but the muffler, AFE intake, two JL 10's, all new interior speakers, PPE HOT, titan tank, bed liner, 10inch adjustable drop hitch, and more to come!
there is kind of a switch w/o efi live a lot like the doge and ford guys with a disconnect switch and resistor on the maf but theres a lot of limp issues and check engine lights
