Old 11-05-2009, 04:37 PM   eBay Motors   #1 (permalink)
HECKS
HECKS's Avatar
Installing Straight Exhaust ?
Quick question, I'm installing a 5" straight pipe exhaust this weekend, and I was wondering if you need to install any kind heat wrap or tape at the exhaust clamps, or do the clamps seal tight enough not to leak ?
2005 2500HD LLY CCSB 4x4
AFE INTAKE STAGE II
5" HUSKER STRAIGHT PIPED, EGR DELETE
PPE HOT+2 E.T.
AUTO METER PHANTOM WATER/PYRO/BOOST GAUGES
BD EXHAUST MANIFOLD, AFE BLADERUNNER,
SUNCOAST IV NADP HEAVY HAULER TRANNY w/ DEEP PAN
COGNITO BRACES, 20" A.R. RIMS w/ BFG AT'S 305/33
HECKS is offline   Reply With Quote
Old 11-05-2009, 04:41 PM   eBay Motors   #2 (permalink)
jbrown1132
jbrown1132's Avatar
clamps is all thats needed nothing else. nice avatar by the way
'05 2500hd cc sb 4x4
Dmax 6.6turbo/Allison
Stealth 2, EGR blocked, PVC rerouted, kodiac mp
autometer sportcomp gauges
B&W gn hitch and 5th wheel conversion
5% window tint, gm nerf bars, remote start
kitty stays in the shop
http://www.performancetruckproducts.com
jbrown1132 is offline   Reply With Quote
Old 11-05-2009, 04:50 PM   eBay Motors   #3 (permalink)
DuraVette
DuraVette's Avatar
Just make sure clamps are good and tight and thats all thats needed.
2008 3500 CCLB LTZ Dually
All stock for now except for the B&W turnover
SOLD-2007.5 2500HD CCSB LTZ
MBRP 4" straight with 5" tip
Quadzilla
B&W turnover
DuraVette is offline   Reply With Quote
Old 11-05-2009, 04:51 PM   eBay Motors   #4 (permalink)
HECKS
HECKS's Avatar
I will probably use some lock tight on 'em. Thanks
AFE INTAKE STAGE II
PPE HOT+2 E.T.
Old 11-06-2009, 12:08 AM   eBay Motors   #5 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
What kind of clamps does it come with? The band clamp types are the best. They will form to the pipes. The U bolt pipes crush the pipes together. Both of them seal great and you are suppose to crank them down good so you dont need thread lock.
Jason
Old 11-06-2009, 04:05 PM   eBay Motors   #6 (permalink)
MillersHighLife
MillersHighLife's Avatar
walker makes a sealant for clamped joints called accustaseal or somthing like that . its is a black tar like sealant that helps seal and prevents the pipes from seizing together for easy removal later on down the road . i put a bead around the inside of the joint slide the next pipe in then clamp it down .
04 2500HD , Recon black smoked l.e.d. cab lights , "off road" Diamond Eye 4" cat delete downpipe back exhuast , and let me tell ya getting to work only going "off road" really ticks off your neighbors
MillersHighLife is offline   Reply With Quote
