Lift pump ??? - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 22 (permalink) Old 02-04-2008, 06:16 PM
custom8726's Avatar
Rob, Do you have the dual tts lift pump's in stock??? I have made several attemp's to buy them from steve cole at TTS, But apparently he has been to busy to call or E-mail me back.
Thank's Jason
2012 Denali H.Dů Cognito Lift, Fox shocks etc etc
05-LLY-crewcab-SB- 285-65-18's on MKW wheel's, -AFE STAGE 2-MBRP DUALS-EGR BLOCK PLATE-AUTOMETER PYRO+BOOST GAUGES- B&W turn over, Diamond + JL AUDIO, Remote starter,Turbo timer, Tranny upgrade, PRECISION T.C., Deep pan, Fumoto valve, AIRDOG 150 L.P., PPE SHIM KIT & PORTED FUEL RAIL, LBZ mouth piece, COGNITO H.D. TIE RODS & BRACES.
EFI LIVE, DSP-5...... ATP TUNING, 40 over BD Injectors 4" T.C. lift, 35" Nitto graplers, Rancho 9000's
Built motor, "Big Twin's", Dual Fuelers
04 - LB7 Reg Cab (Current race truck project) youcrazyy
custom8726 is offline
post #12 of 22 (permalink) Old 02-16-2008, 04:14 PM
Rob
How are the raptors for lift pumps and would you mount a filter system like nicktane before or after the pump?
Thanks
MWDHAND is offline
post #13 of 22 (permalink) Old 02-16-2008, 04:45 PM
D2THAMAX's Avatar
Send a message via MSN to D2THAMAX
Arent the TTS and Kennedy setups the same pumps just different on how the wiring is?
2005 WHITE DMAX/ALLI CREW CAB SHORT BED, AUTOMETER C2 PYRO BOOST AND FUEL PRESSURE, AFE STAGE 2 INTAKE, SILVERLINE DUAL 4 INCH STRAIGHT PIPES, DIAMOND EYE TRUE DOWN PIPE, BLOCKED EGR, EFI LIVE, FLEECE PERFORMANCE 70MM CHEETAH TURBO:rockin, ATS EXTREME TRANS 5 STAR TC and COPILOT. SUNCOAST T CASE BRACE, BD BLOW OFF VALVE , FULL BORE MANIFOLD, COOL DOWN TIMER, TTS DUAL LIFT PUMPS, PPE RACE VALVE, FABTECH HD TIERODS,CALTRACS COGNITO BRACES, T BARS LOWERED, 20INCH ICE METALS WRAPPED WITH 305 50 TOYO PROXES.
D2THAMAX is offline
post #14 of 22 (permalink) Old 06-01-2009, 04:10 PM
97Cobra's Avatar
I have a 2002 with bully dog power pup (always on extreme) lol and straight pipe. Would a single lift pump kit be plenty? I'm in the dark when it comes to diesels so any help would be much appreciated.
It has a code for "low rail pressure" could could the lift pump possibly solve that problem?
03 SVT Focus, 02 2500HD, 97 SVT Cobra S/C, 90 GT TT, 81 Scrambler
Straight pipe, K&N, Bully Dog, PPE Boost valve, TTS lift pump, 20" MM 950's/General Grabbers.
97Cobra is offline
post #15 of 22 (permalink) Old 06-01-2009, 04:38 PM
812-200-2200
Meyerperformance's Avatar
A lift pump would provide more fuel to the rail. It also helps prolong the life of the CP3. I would look into a AD 100 or 150. Let me know if you have any questions.
Tyler
MPF
Meyerperformance is offline
post #16 of 22 (permalink) Old 06-01-2009, 05:07 PM
AlligatorPerformance's Avatar
My FASS 150 maintains rail pressure with my biggest tunes, and is always positive on the pressure gauge. I think the lowest I've seen it was 4 psi. And it comes with everything you need to install w/o dropping the tank, and is flow through enough to limp home at 2K rpms or below. Plus it has a lifetime warranty, and is built to last 13,000 hours.
Alligator Diesel Performance - Chad Hall Owner 1-866-255-7212
Shop Location - 4470 W. Seltice Way, Ste. E - Post Falls, ID 83854
DPF Delete PKG's - Gauge Packages - PRICE BEAT GUARANTEE - Blocker Plates
AlligatorPerformance is offline
post #17 of 22 (permalink) Old 05-14-2014, 08:54 PM
Tyler
MPF
Is a lift pump that pump that you have to keep your fuel tank about 1/4 of a tank otherwise it doesnt work?
Rickywall is offline
post #18 of 22 (permalink) Old 05-21-2014, 08:08 PM
rikrod's Avatar
I have a raptor 150 with a cat pre filter. No complaints yet
2005 crew cab 4x4. 4" exhaust, no muffler or cat
LBZ mouthpiece, banks cold air, PPE fuel race plug, PVC reroute, 2" resinator plug, edge evolution CTS, raptor 150 lift pump with a pre filter, kicker CVT, kicker 750w amp
rikrod is offline
post #19 of 22 (permalink) Old 05-28-2014, 03:52 AM
Air dog 150 and still one of my favorite upgrades
burris9 is offline
post #20 of 22 (permalink) Old 06-01-2014, 12:14 PM
have 2008 chev. 6.6L diesel. message says engine power reduce-change fuel filter. I changed filter, but nothing changes. Vehicle goes into limp mode. What could this be? Also, where is the fuel lift pump located?
bhurdle is offline
