Yeah you should be okay with that size you may have a little bit of fender rub at full lock on the steering. If you want you can give the torsion bar adjuster bolts a few turns and raise the front end up just a touch.
__________________ John
05' Dmax LLY CC SB, 6in. Fabtech with Heavy duty tie rods,
FOX 2.0's shocks, 35in. MICKEY ATZ's, 20in. KMC's,
6000K HID headlights & fogs, AirDog 150
PPE Hot Xcelerator, 4in straight exhaust, Afe stage II intake,
Killerbee Compressor Mouthpiece, PCV re-route
06' Pontiac GTO 6.0L (Bone Stock)
I was not able to fit my tires which are BFG All Terrains 285/65/18 on 18"X9" 4.5" back spacing. The tires show on the BFG web site as 33" tall tires, but I measured them at 31.5". Also, I had to trim the lower bumber trim and twist the bars up 2" and now the clear in all conditions. I hope this helps you.
yes you can fit a 33" tire under a 3/4Ton GM truck but depending what wheels you have will make a big difference how hard they rub or if they rub at all,like a 20" wheel if it is a 10" wide wheel with a 5"BP yes they will rub but if you drop that down to a 9" wide wheel with a 4.5"BP and run the same tire your chance of them rubbing has been cut in half.what i'm trying to say is don't go with too wide of a wheel and try to stay with a 4.5"BP versus a 5"BP for the most part..hope this helps
ps you'll have to crank the T/Bars up to clear 33" tires.
__________________ James
TyreBoyz Pulling Team
Puller/DD=04 LLY Reg Cab 2500HD,EFILive with DSP5,Stage 5 SunCoast,Stage 3 Snow Performance,BD,Ported Rail fittings,Race Valve,LMM CP3,EGR Delete,IFS Upgrade,6" Staxs and AutoMeter Gauges.i think thats it
06 LBZ 2500 CC SB SRW,built trans and tuned by Idaho Rob and PPE at times with EFILive.
i though i would have to crank up the t-bars. im getting the 20x10 XD rockstars 4.5"BS -24 offset. the tire size i said above ___ nitto dune grapplers is what i want fitted on these wheels.
__________________ 04.5 LLY edge with attitude, 5" MBRP turbo back exhaust, S&B intake, B&W turn over ball
I may as well add to this chat...I was looking into stepping up to a 285/75/16 on the stock wheels when my truck needs new tires...I just got it a week ago but tires don't last real long in my neck of the woods (I have a heavy foot). I was just wondering if these tires would fit and how much rubbing I am going to have to deal with?
