Old 03-19-2008, 12:26 PM   eBay Motors   #1 (permalink)
psyco66
Points: 3,473, Level: 24
Points: 3,473, Level: 24 Points: 3,473, Level: 24 Points: 3,473, Level: 24
Activity: 2%
Activity: 2% Activity: 2% Activity: 2%
psyco66's Avatar
Guage lights
Hi. I am installing a boost guage and a pyro guage this weekend on my truck. I was wondering has anyone hooked the lights in the guages up so when you dime your dash lights the guage lights dime. I am a great machanic but I suck at electrical. Any help would be great. My truck is a Chevy 05 LLY if that helps. Thanks for your time. I did a search and could not find what I needed.
John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me.
NO TALKING JUST LINE IT UP
psyco66 is offline   Reply With Quote
Old 03-19-2008, 01:45 PM   eBay Motors   #2 (permalink)
Landscapeman
What Mailbox?
Points: 3,204, Level: 23
Points: 3,204, Level: 23 Points: 3,204, Level: 23 Points: 3,204, Level: 23
Activity: 2%
Landscapeman's Avatar
I would find a wire schematic and tap into the harness. Good Luck
2006 GMC 2500HD LBZ Crew Cab 4x4, Silverline Turbo Back Dual Exhaust, PPE Hot Programmer, Egr Block Plate, PPE Air Box Mod, 2in. Plug, SES Light
Full Bore Exhaust Manifold compliments of BD Diesel.
Landscapeman is offline   Reply With Quote
Old 03-19-2008, 03:41 PM   eBay Motors   #3 (permalink)
BigBlue'06
Points: 1,169, Level: 13
Points: 1,169, Level: 13 Points: 1,169, Level: 13 Points: 1,169, Level: 13
Activity: 0%
BigBlue'06's Avatar
If you will pull the headlight switch out of the dash you can tap into the actual dimmer wire. On mine it was the Brown with white stripe wire.
'06 3500 Crew Cab LT
Long Bed LLY, 6 inch Fabtech
Lift, 35/12.50 17 Pro Comp Tires,
PPE CAI intake mod, AFE Pro Dry Filter,
Diablo Predator, Autometer Ultra Lite II
Pyro & Boost Gauges, Hitch Cam, Headrest
DVD System.
BigBlue'06 is offline   Reply With Quote
Old 03-19-2008, 04:48 PM   eBay Motors   #4 (permalink)
psyco66
Activity: 2%
psyco66's Avatar
Cool that is what I thought. I just wanted to make sure before I started to rip the dash apart.
John
Old 03-19-2008, 05:14 PM   eBay Motors   #5 (permalink)
BigBlue'06
Activity: 0%
BigBlue'06's Avatar
It was real easy. Pull the trim ring loose, you don't have to remove it all the way, just enough to get the headlight switch box out. To remove the box there was a clip on top and 1 or 2 on the bottom, you'll see how they work when you look at it, the box will just pop out. Good Luck.
DVD System.
Old 03-19-2008, 05:23 PM   eBay Motors   #6 (permalink)
psyco66
Activity: 2%
psyco66's Avatar
Thanks for the info. I love this site.
John
Old 03-19-2008, 05:34 PM   eBay Motors   #7 (permalink)
rotcartdj
Points: 469, Level: 7
Points: 469, Level: 7 Points: 469, Level: 7 Points: 469, Level: 7
Activity: 2%
I just wired my boost gauge and I pulled the dash trim and the guage cluster and tapped into the wiring harness that plugs into it. You can take your wire from the gauges and plug it into the harness to find the wire that controls the dash lights. For my truck it was a red wire.
2004 Chevy 2500HD EC Short Box w/LB7 ZF-6 speed
255/85-R16 Remington Mud Brutes on factory rims with 2" Lift Front and Rear
Straight piped. Kennedy Air Box Mod. AFE Drop-In Filter. CrankitupDiesel Tie Rod Sleeves
Autometer Phantom II Boost and Pyro w/ overhead console mount
FUTURE UPGRADES
Exhaust 4in Turbo Back
PPE Standard
Cognito Braces
And the list goes on and on
rotcartdj is offline   Reply With Quote
Old 03-19-2008, 05:41 PM   eBay Motors   #8 (permalink)
psyco66
Activity: 2%
psyco66's Avatar
Do the guage lights dime with the dash lights that is what I am trying go get.
John
Old 03-19-2008, 05:56 PM   eBay Motors   #9 (permalink)
rotcartdj
Activity: 2%
Had to go out and check. I had not tried to dim them. It does dim but not at the same rate as the dash lights. I also saw that Autometer makes a dimmer switch for there gauges if you have that kind. Hope this helps.
FUTURE UPGRADES
PPE Standard
Cognito Braces
Old 03-19-2008, 05:59 PM   eBay Motors   #10 (permalink)
psyco66
Activity: 2%
psyco66's Avatar
Cool thanks.
John
