Old 08-03-2008, 03:28 PM   eBay Motors   #41 (permalink)
NASTYHAULER
NASTYHAULER's Avatar
Very true.....That's why I said I thought I sounded like a dumb arse for asking that question and you verified that thought...LOL!! Oh well pretend I never ask that question....
The Official Nasty Hauler MySpace Page
THE NASTYHAULER
2005 CHEVY 2500 EXT. CAB SHORT BED
INCUBUS 20X9 GRIMS +20MM OFFSET & 275/65/20 GOODYEAR ATS
JVC IN DASH DVD PLAYER WITH SIRIUS SATELLITE RADIO
KENWOOD AMP AND PYLE 10" SUBS
WINDOWS TINTED 5% ALL THE WAY AROUND
T-BARS TURNED UP 1"
MEYER PERFORMANCE/MBRP 4" STRAIGHT PIPE EXHAUST WITH NICE SHINEY TIP! MODIFIED MOUTHPIECE, RESONATOR PLUGGED,PPE TUNER SET OF LEVEL 3.
"A gun in the hands of a free man frightens and angers the GOVERNMENT, not because they fear the power of the gun, but, rather, the spirit of the man who holds it."
NASTYHAULER is offline   Reply With Quote
Old 08-03-2008, 03:31 PM   eBay Motors   #42 (permalink)
daddysLBZ
ONEFASTCOONASS..
daddysLBZ's Avatar
Originally Posted by NASTYHAULER View Post
I have a question, we use it on our race car, basically it's a roll of heat resistant header wrap that we use to wrap the primary tubes in the engine compartment to cut down on the heat around the starter and other componets. My question is or would it be to my advantage to wrap the Intake Tube from the box over to the mouth piece? Seeing that the Intake Tube runs right over the motor and intake where all the heat is at. I'da know just an idea, I was kinda thinking it would keep the heat from soaking in to the plastic and increasing air temps....okay after reading over this I sound like dumb arse for asking but I gotta.
not bad idea,nice brainstorm there,may be worth tryin,,let us know of any improvments you observe....
06.LBZ GMC[SLE1] 4x4 ....114k miles,4136 hours[Modded a bit.LOL]
1987 Monte Carlo SS 89k
1978 Malibu
FORMER DURAMAX FORUM MODERATOR...........i HAVE YOUR iNTERNET pROVIDER ADDRESS...:tease
Old 08-04-2008, 06:16 AM   eBay Motors   #43 (permalink)
Killerbee
Killerbee's Avatar
By far the best way to keep heat out of the intake, is at the air source...the box. Put all your attention there, it is plenty defective.
Michael, 2500HD LLY, Systems Engineer, EMAIL
PRODUCT PAGE CUSTOM TUNING
Quick Links:ECM's , INDUCTION OVERHAUL, EFILive,
NEW Lockable DSP Switches coming DEC 1
Old 09-19-2008, 10:30 PM   eBay Motors   #44 (permalink)
mattfromwy
mattfromwy's Avatar
sounds great guess i have to get off my a$# and break out the power tools.
2004 GMC 2500HD LLY HOMETOWN BILLINGS,MT HOME OF THE DIRTYMAX 9.46@149 G&J DIESEL
Edge Juice with Attitude
Crank it up Tierod sleeves
Turbo Resinator Plugged
4" Turbo Back dead kitty No muff (MBRP) 6? Miter Cut Black Stacks
6'' Rancho Lift
17" Procomp Rims 35? Cooper STT
Tinted Windows
Spray In Bedliner, also on the bottom 6'' of truck
Traxx By Kat Radar Detector/Laser Scrambler & Peformance Meter
Custom Built Grill Guard; Bolinger Inc;
mattfromwy is offline   Reply With Quote
Old 09-28-2008, 12:04 AM   eBay Motors   #45 (permalink)
Paccool
Killerbee, you have some really good information. Thanks for all the help so far!I still want to get that ported mouthpiece, will just take a little time. I want to do some more testing first. Want to check temps in the air box stock and then with some mods to see the difference.
One thing I have not seen anyone discuss (I'm still trying to get everything read since I'm new here) is adding additional holes on the inner fender where the foil/rubber patch is at. I have some panel punches and was thinking of adding a few 1.5" holes in that area for more cold air. (or maybe a 3" hole with a hole saw if done carefully) Still need to look at this carefully before doing it.
I pulled the foil off the inner fender for cooler air and then modified the front of the air box with a 3" hole saw. I want to run a 3" flex hose up from the behind the bumper into that hole. I also have sealed around the fender side of the air box as well as along both sides to stop hot air from getting in there. Pulled the trailer great, all temps stayed down. (Still don't have an EGT gauge yet). The tranny temp ran about 150-160 except on a long grade where it went up to about 190. Engine temp stayed right at 210.
Ambient air was only in the 60's so it was pretty cool outside.
Stan
2005 Chevy Silverado 4x4, 285-70-17's on Hummer wheels. 24,000 miles. Banks Ram Air inlet system. Predator programmer, KillerBee modified mouth piece.
93 Dodge D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust,modified tranny,EGT/boost/tranny/tach gauges.Rear sway bar.Single stage Water/Meth system installed. Oversized intercooler
Paccool is offline   Reply With Quote
Old 09-28-2008, 12:26 AM   eBay Motors   #46 (permalink)
BigRedChevy
Super Moderator
BigRedChevy's Avatar
Be very careful in the rain if you run the flex pipe up to that hole. These engines such a lot of air and if its raining hard enough will such a lot of water through that pipe.
KYLE
2010 Camaro SS LS3 426 HP
Old 09-28-2008, 10:12 PM   eBay Motors   #47 (permalink)
Paccool
Kyle,
I've been thinking about that and wondering if it would suck up the water. If I stop it behind the bumper area, it would be protected from most of the drops. Probably won't put a scoop on it but might flare the inlet an inch or so to help get air into the hose.
Might be able to leave a gap at the bottom of the hose for any water that might be pulled up a place to drain off.
I can see I'll need to think about this some more.
Stan
Old 10-19-2008, 07:11 AM   eBay Motors   #48 (permalink)
Prairiefire
Any results with the air box yet
Prairiefire is offline   Reply With Quote
Old 10-19-2008, 10:23 PM   eBay Motors   #49 (permalink)
Paccool
If you are asking me that question, the answer is no. I have been on a business trip for the past 8 days and just got back home this afternoon. (Sunday)
Got the KB mouthpiece on today after I got home but still need to play with the box and check some temps.
Stan
Old 10-19-2008, 10:51 PM   eBay Motors   #50 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Because of the occasional bug I find on the K&N filter, I feel the area under the headlight from the side facing the grill area may be more of a source for moisture than from the tire well.
