| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 04.5-05 LLY Performance Parts Discussion Discussion of Performance Parts For the 04.5-05 LLY Duramax Trucks No Advertising |  | |
04-11-2008, 11:36 AM
eBay Motors
#1 (permalink)
| | Junior Member
| turbo bark not good for turbos? something ive heard and always wondered |
| Advertisement
04-11-2008, 02:16 PM
eBay Motors
#2 (permalink)
| | Member
| Doesn't hurt them. It is a turbo "stall", the fins cant catch up with the air. I work for Cummins and this is a fairly common problem on the Heavy duty engines
__________________ 2005 cc sb LLY allison, 4x4,20x9 wheels 285/55/20 Nitto Dune Grapplers, De-Badged,strait piped, Everything's for sale!! |
04-11-2008, 02:34 PM
eBay Motors
#3 (permalink)
| | Duramax Forum Moderator
| I wouldn't want to go around doing it all the time, but if it happens don't worry about it.
__________________ KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan EFI Live is on the way!!!!
04-11-2008, 04:25 PM
eBay Motors
#4 (permalink)
| | ATS Tech Support
| Quote:
Originally Posted by tireburnin54 Doesn't hurt them. It is a turbo "stall", the fins cant catch up with the air. I work for Cummins and this is a fairly common problem on the Heavy duty engines | I beg to differ......thats how my factory turbo went  . Basically what happens is your turbo is spinning at 120,000+ rpm and when it barks, it is dropping as much as 40-50,000 rpm in a split second. This can bend shafts, hence grenade your turbo.
__________________ 2003 GMC Sierra LB7 ATS *EXTREME* Transmission, ATS Aurora 4000 MST, ATS Dual 4" Exhaust, ATS Epower Programmer, Custom 4" Intake with AFE Filter, ATS Billet Tie Rod Sleeves www.atsdiesel.com 866-230-4092 |
04-11-2008, 11:19 PM
eBay Motors
#5 (permalink)
| | Moderator
| Ya definatly not a good thing. I only had mine bark one time when I was doing a burn out and hit the brakes.
__________________ 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 2 MTX 10in Subs & Punch 250amp in a custom box. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 265/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
04-14-2008, 06:00 AM
eBay Motors
#6 (permalink)
| | DuramaxForum Fanatic
| The bark noise comes from airflow disturbance, blade stall that results from an excessive pressure ratio, Page Ranking. It is an enormous mechanical stress.
Part of what makes it so bad on the LLY, is the restricted compressor mouthpiece. I am testing the removal of that restriction on bark. |
04-14-2008, 06:30 AM
eBay Motors
#7 (permalink)
| | Senior Member
| Don’t diesel trucks and cars bark every time you get out of it to some extent? Gas turbo cars and trucks all have one thing that diesel cars and trucks don't have throttle blades (except for new trucks that have them for emissions).
when a gas car or truck with a turbo closes its throttle, the engine goes into vacuum which sends a single via vacuum hose to the blow off valve which releases the built up turbo presser to keep it from surging back ageist the turbo and stalling it.
So if your truck dose not have throttle blades or a blow off valve then every time you’re under load and get out of the throttle (pulling a trailer up a hill and some jackass cuts you off) the pressure will surge back to the turbo to some extent. So you would think that the factory would build accordingly?
I might be wrong but I think that’s how it works.
__________________ Black 2008 Chevy Crew Cab Short Bed
4x4 Z71 LTZ LMM
Speedliner
WeatherTech FloorLiners
B&W Turnover Ball Previous Rides
2005 F-250 all done up to the point the heads popped right off the block!
2002 ZR2 all done up to the point where there was not a straight unscratched piece of sheet metal on it! |
05-02-2008, 12:13 PM
eBay Motors
#8 (permalink)
| | Junior Member
| well, my turbo is insanely loud. and even under going normal throttle conditions, letting off the throttle and even when it shifts you can hear it. im assuming at such as slow rate of air that its not doing much damage at that rate but more towards WOT and letting off could be bad. |
05-09-2008, 02:50 PM
eBay Motors
#9 (permalink)
| | DF Sponsors
| What happens is you have all this exhaust energy driving the turbo. That in turn has the compressor wheel compressing air and sending it through the intercooler and then into the engine. When you let off the throttle quickly you no longer have the exhaust energy driving the turbo, but you have all that pressurized air on the compressor side. It is looking for the easiest way out. The easiest way out isn't to continue on to the motor, but to try and come back through the turbo. This causes the compressor wheel to slow dramatically which can hurt either the wheel or the shaft. Not a good thing
05-09-2008, 10:38 PM
eBay Motors
#10 (permalink)
| | Moderator
| Quote:
| Advertisement
