Nice pics. Those vents are the water protection for rain. From what I can see there, it still won't protect from standing water. Is there a source for air higher up? If so, then water is heavy enough it won't fill that duct. But if there isn't, better not go through any deep puddles that will cover those openings.
There is not going to be any noticeable ram benefit either. This is a 20 psi vehicle. Ram benefits never exceed .3 psi at our speeds. It's not a 600 mph fighter.
What you do have is a superior Cold Air intake, IMO. And in the LLY, that's huge. However. they still left the most performance degrading intake piece in place. Intakes are a big con, in general. Your gains are going to be substantially lower than placebo is suggestion.
Make sure you bring the old intake to the dyno, and compare them.
Oh nice i can do that get someone to take the tire off for me and I can sort of sit on a chair and do this. Ill take some more pics.
i use a bucket but a nice lawn chair would work to..
we have sevaral tire shops so taking tires off is easy for me and it's realy not that hard for most people..jack the truck up and put a jack stand underneath the frame behind the left front tire and then you can start working..
__________________ James
TyreBoyz Pulling Team
I really like the looks of the intake cant wait to see the dyno results I dont it very much if any but will see
__________________ Meyer Performance & Fabrication, LLC Home of your diesel performance needs. www.meyerperformance.com (812)-344-4421 Tyler Quadzilla Sale pm for details. Airdog Sale EXTENDED till Jan. 31st. Transgo jr. $120 shipped
07.5 Summit White RCLB. DPF deleted, Cobalt gauges, Banks intake, Fire & ICE.
Killerbee You never answered the question. What is the part that needs to be modified on the LLY.
the intake is 3" at the compresor elbow. The only thing i could see possing a restriction in flow and introducing tuburl;ance is the whissle baffle at the turbo.
By the way here is a pic of what im talking about look at the side of the air box. The big opening on the side when u buy the scoop kit you get a block of plate that slides in there when you have the scoop on. See a water hole you pull it out and no worring of hydrolocking.
As for the dyno ill slap on the stock on first and dyno it then slap do 2 runs with the stock one then do the banks system with no scoop then with the scoop.
As for guys who doubt this intake makes power i used to do alot of NA aib box mods back in the day. Example the inside of the air box you know the squares on the inside of the lids and box by grinding them off and smoothing them on a NA motor reveing to 9000 rpm we picked up 4whp on the top end.
If you look at the banks intake starts off as a 8" inlet to the filter and funnels smaller at the flex joint 4.5" then at the throtle body 3". This creats a velocity effecy.
If you look at the factory intake its 3.5" all the way to the throtle body with a 1/8" lip all around the throtle body which creats a turbulance effect.
You can read all about it in the next issue of Maxxtorque. It is all the results from a one year intake analysis effort.
The conclusion is something none of the intake manufacturers have tested for. I guarantee it will be worth the trouble.
Thats ur filter usage gauge lol When your filter gets clogged up creats vacum pulling the diaphram back to tell u to change it. that would take a longggg time with thishuge filter and its surface area.
