Old 05-17-2008, 06:44 AM   eBay Motors   #41 (permalink)
Killerbee
Points: 1,949, Level: 17
Points: 1,949, Level: 17 Points: 1,949, Level: 17 Points: 1,949, Level: 17
Activity: 18%
Activity: 18% Activity: 18% Activity: 18%
Killerbee's Avatar
Originally Posted by JDMDCRX View Post
Killerbee You never answered the question. What is the part that needs to be modified on the LLY.
the intake is 3" at the compresor elbow. The only thing i could see possing a restriction in flow and introducing tuburl;ance is the whissle baffle at the turbo.
By the way here is a pic of what im talking about look at the side of the air box. The big opening on the side when u buy the scoop kit you get a block of plate that slides in there when you have the scoop on. See a water hole you pull it out and no worring of hydrolocking.
As for the dyno ill slap on the stock on first and dyno it then slap do 2 runs with the stock one then do the banks system with no scoop then with the scoop.
You can read all about it in the next issue of Maxxtorque. It is all the results from a one year intake analysis effort.
The conclusion is something none of the intake manufacturers have tested for. I guarantee it will be worth the trouble.
Michael, 2500HD LLY
Vehicle Systems Engineer-useful links
LLY INDUCTION OVERHAUL and HEATUP CURE
www.maxxTORQUE.com
OVERHEATING? Thermal Feedback Loops
EFILive Tutorial
Old 05-17-2008, 12:22 PM   eBay Motors   #42 (permalink)
TheHoov
Points: 1,991, Level: 18
Points: 1,991, Level: 18 Points: 1,991, Level: 18 Points: 1,991, Level: 18
Activity: 96%
Activity: 96% Activity: 96% Activity: 96%
TheHoov's Avatar
On the first pictures you posted what is the little cylinder thing located by the filter part that is green and red.
2002 Chevy LB7 Crew Cab
16 inch Helix Rims and 285 Nitto Terra Grapplers
Thank you Duramax Forums
TheHoov is offline   Reply With Quote
Old 05-17-2008, 01:17 PM   eBay Motors   #43 (permalink)
JDMDCRX
Points: 815, Level: 11
Points: 815, Level: 11 Points: 815, Level: 11 Points: 815, Level: 11
Activity: 2%
Activity: 2% Activity: 2% Activity: 2%
Thats ur filter usage gauge lol When your filter gets clogged up creats vacum pulling the diaphram back to tell u to change it. that would take a longggg time with thishuge filter and its surface area.
JDMDCRX is offline   Reply With Quote
Old 05-18-2008, 07:38 AM   eBay Motors   #44 (permalink)
Killerbee
Activity: 18%
Killerbee's Avatar
it has less than 1/3rd the surface area of the stock element.
Michael, 2500HD LLY
www.maxxTORQUE.com
EFILive Tutorial
Old 05-18-2008, 11:05 AM   eBay Motors   #45 (permalink)
TheHoov
Activity: 96%
TheHoov's Avatar
OK thank you for explaining it.
Old 05-18-2008, 11:06 AM   eBay Motors   #46 (permalink)
TheHoov
Activity: 96%
TheHoov's Avatar
Wait the Banks intake has less surface area that the stock paper filter?? It has to have better air flow right?!
Old 05-18-2008, 03:32 PM   eBay Motors   #47 (permalink)
JDMDCRX
Activity: 2%
There are so many factors that play into effect of a intake. It has 1/3 the surface eh. Do your math the surface area of the stock filter is 40 sq in in surface area banks filter 72 sq in how is the stock bigger ?
Old 05-18-2008, 06:44 PM   eBay Motors   #48 (permalink)
BigRedChevy
Duramax Forum Moderator
Points: 4,817, Level: 29
Points: 4,817, Level: 29 Points: 4,817, Level: 29 Points: 4,817, Level: 29
Activity: 100%
BigRedChevy's Avatar
The are more pleats and they are deeper on the stock filter. You have to take that into consideration also. Killerbee has done extensive research on this subject and knows what he is talking about.
KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan
EFI Live is on the way!!!!
Old 05-18-2008, 10:35 PM   eBay Motors   #49 (permalink)
JDMDCRX
Activity: 2%
more pleats sure traps more are at the tips of the pleats. Look at how a stock panel filter wears and you will see its main air stream this were you air stream goes threw once this area gets clogged full of debree and dirt the air stream starts to funnel from the outer edges. Trust me i know how a air filter works ive done lots of flow bench work in the military and civi side.
So far the gas millage is up a bit but i will make judge after a few more tanks of gas. We were getting on avg 16.5-16.7L per 100km. These last to tanks 16.0-16.2L per 100km.
My dads drive normal is setting 4 all the time.
But i still need to see if the previous owner change the diameter for the 285 tires in the ECU
Old 05-18-2008, 10:57 PM   eBay Motors   #50 (permalink)
4x4Fantasy
Points: 2,048, Level: 18
Points: 2,048, Level: 18 Points: 2,048, Level: 18 Points: 2,048, Level: 18
Activity: 64%
Activity: 64% Activity: 64% Activity: 64%
4x4Fantasy's Avatar
To convert to U.S. standards of MPG, you were getting 14.0 - 14.3 and now you are getting 14.5 - 14.7 mpg.
An increase in a half mile per gallon is not bad at all !!
4x4Fantasy is offline   Reply With Quote
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
