Originally Posted by kcarson I just changed the spin on filter, and the trans fluid. I've got the Edge Juice and have only run it on level 2. That doesn't seem like it should be too much power when you're just passing with out a trailer on back. Should I consider one of those extra deep sump pans for the trans? |
Are you the first owner of your truck?? Reason for asking is the person before you could have used a handheld programmer and beat the tar out of it....that is why you could be having your problems...if they are tranny related. Have you tried to take it anywhere for codes to be checked? As far as tranny fluid...any quality synthetic is good.....Mobil 1 (it's what I use), transynd, and amsoil...there are more, but those are the 3 most people use.
AFE Magnum Force Stage 2 Proguard 7 intake Waiting install:Rancho Steering stabilizer....all thanks to NorCal Truck Support your Supporting Vendors |
