| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | 04.5-05 LLY Performance Parts Discussion Discussion of Performance Parts For the 04.5-05 LLY Duramax Trucks No Advertising |  | |
06-13-2008, 09:41 AM
eBay Motors
#31 (permalink)
| | Senior Member
| Air in - Air Out !!! The first thing you should do is put at least 4" exhaust on it and then maybe look into a cold air intake. If you can't get the air out, you won't get it in either, thus, slower spooling time! That will increase your off the line speed some. Also, the turbo resinator plug will help a little and costs only a couple bucks.
As for the Edge only reading 22.5 lbs. The other nite I smoked a 5.0 Mustang and saw 33 lbs as a guick glance and I believe it went higher. I was on #4 and didn't go a really long distance. It's funny how something like that only lasts a short time and you wonder how much boost, how high did EGT's go, and yet you want to watch the guy gettin smoked!!
__________________ HAD - 94 Chevy Dually 4x4 - 6.5 Turbo
96 Chevy Ext.cab 4x4 - 6.5 Turbo
99 GMC Dually 4x4 - 6.5 Turbo
HAVE - 2005 GMC Sierra crew/6'box - 4X4 - Duramax w/Allison. Fully loaded - AiRaid intake - 4" Pinnicle Performance Exhaust (No Converter - Straight through muffler) - EGR blocker plate - Edge Juice w/attitude - 2" plug in Turbo Resinator - |
| Advertisement
06-13-2008, 10:08 AM
eBay Motors
#32 (permalink)
| | Junior Member
| Nice kill !! Love beating up on any sports car out there, know one expects a diesel to smoke there azz ! My edge for some reason would only read 22.5 psi, when it actually is alot higher, could just be the trucks ECM or the module, no big deal, I have some gauges mounted now, but switched to a PPE hot+2, it works really good but runs some high egt's in the hot settings. PATCHS4, what kind of egt's are you hitting on level 4 ?
__________________ 2005 2500HD LLY CC SB 4x4
AFE INTAKE STAGE II, 4" DUALS, NO CAT, EGR DELETE,
RESONATOR PLUGGED, PPE HOT+2 E.T., AUTO METER PHANTOM WATER/PYRO/BOOST GAUGES, BD EXHAUST MANIFOLD, MODIFIED TURBO MOUTH PIECE, NADP (SUNCOAST) HEAVY HAULER TRANS. w/ DEEP PAN, COGNITO BRACES, 20" A.R. RIMS w/ BFG AT'S 305/55/20 |
06-13-2008, 11:39 AM
eBay Motors
#33 (permalink)
| | Senior Member
| Wish I knew!! I'll bet they are pretty high! I have only put it up there on two occassions and both times I forgot to look at the egt's. Too busy watching the road to check on everything I guess. I know that on #3 on a hill if I get right after it, I have seen 1300, but I think it is set to start defueling at 1350! To be honest, this thing has so much power that I am afraid of smoking the tranny. Imagine that, on 70% WVO too!! Dam - I Love This Truck!!
06-13-2008, 10:30 PM
eBay Motors
#34 (permalink)
| | Senior Member
| I plugged the resonator,have banks intake,and have 5" cat-back (worried about voiding my warranty by taking off the cat).I haven't been building up boost because I'm worried about my torque converter.
__________________ 05 Duramax Ext.Cab Short Bed w/5" Turbo Back Exhaust,debadged,Camoclad exterior(advantage max4 hd),blocked egr and fingerstick,Banks intake,plugged resonator,Edge Juice w/ attitude,Clifford 2-way remote start,complete a/v system(in-dash,overhead,speakers,subs)
And much more to come |
07-05-2008, 08:27 PM
eBay Motors
#35 (permalink)
| | Duramax Forum Supporter
| I have the edge juice with attuide and love it no codes,about 2mpg better, and with 35's it will still light them up on command.
__________________ 2004 GMC 2500HD LLY
Edge Juice with Attuide
Turbo Resinator Plugged
4" Turbo Back Exaust System (MBRP)
6'' Rough Country Lift
17" Pocomp Rims
35x12.50 Copper STT
Tinted Windows
Spray In Bedliner, also on the bottem 6'' of truck
Custom Built Grill Guard, Bolinger Inc. Buffalo,WY 82834 |
| Advertisement
