Old 06-25-2008, 10:37 PM   eBay Motors   #1 (permalink)
power95
Points: 2,441, Level: 20
Points: 2,441, Level: 20 Points: 2,441, Level: 20 Points: 2,441, Level: 20
Activity: 0%
power95's Avatar
high squeal
i recently put a K&N FIPK on my truck... and sometimes it hisses really loud... it was really bad like 2 weeks after i put it on so i got it looked at and they said it was an intercooler leak somewhere... so i just let it go and now it only hisses half the time... has anyone heard of this???
2004.5 CHEVROLET 2500HD
4 DOOR
LONGBOX
6.6L LLY DURAMAX
power95 is offline   Reply With Quote
Old 06-25-2008, 11:18 PM   eBay Motors   #2 (permalink)
Tow Master
Super Man Moderator
Points: 9,193, Level: 41
Points: 9,193, Level: 41 Points: 9,193, Level: 41 Points: 9,193, Level: 41
Activity: 99%
Activity: 99% Activity: 99% Activity: 99%
Tow Master's Avatar
Id say its normal! Your probably hearing the truck suck air through the less restricted air filter and housing. No leaks or anything.
There is a way to check for leaks. Get a can of starting fluid and with the truck runing spray A SMALL AMOUNT of starting fluid around all the connections. If theres a leak the idle on the truck will raise.
Another thing to look at. I also just recently heard the older duramax's have a peace of metal that rubs through the intercooler tube that runs along the front frame.
Jason
2006 Silverado Shortbed Crew Cab LBZ
Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights
2 MTX 10in Subs & Punch 250amp in a custom box. Autometer Ultralite II Pyro & EGT gauges with pillar pod
MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2
265/75/16 Nitto Terra Grapplers on Gear Alloy wheels
Lost Kitty Reward if found!!
1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake
Old 06-27-2008, 05:15 PM   eBay Motors   #3 (permalink)
jc1843
Points: 317, Level: 6
Points: 317, Level: 6 Points: 317, Level: 6 Points: 317, Level: 6
Activity: 14%
Activity: 14% Activity: 14% Activity: 14%
This will work on a gas engine because they have vacuum in the manifold-- these trucks do not have vacuum, so this will test not work-- unless you have a BIG hole to spray the starting fluid in. However it is very bad practice to use any starting fluid on these engines-- could cause an explosion from the heaters or even worst-- damage the internal parts of the engine.
The boots to the inter cooler get oil soaked from the PVC system and will slip --check the boots and clamps.
Chevy 04.5 LLY, 265s, shell, XDR, TransGo, deep pan, blocked, fingered, de-badged, PVC mod, 65 Gallon Aero tank, Pre-filter, tow mirrors, BU cam, gauges, GPS, Sirius
Old 06-27-2008, 09:04 PM   eBay Motors   #4 (permalink)
daddysLBZ
AIN'T SKEERED!!
Points: 4,135, Level: 27
Points: 4,135, Level: 27 Points: 4,135, Level: 27 Points: 4,135, Level: 27
Activity: 100%
daddysLBZ's Avatar
It IS a good test.BIG holes will be painfully obvious,this is fer the smaller,hard to see ones.I think he said a SMALL amount of spray,outta do it.Got better method,post it up...We know about hydrolocking pistons with start fluid,but when at idle,if ya don't use a TON,you'll be OK...
2006 GMC 2500HD4x4 sb cc LBZ!!!52k
MODS:Full straight pipe,res mod,Superchip tuner
2002 GMC 1500 2wd x-cab-sb 5.3l.
1987 89,000k 305H.O. 700-r4
1978 Malibu[2dr]350/350hp TH-350 trans
Old 06-27-2008, 10:37 PM   eBay Motors   #5 (permalink)
BigRedChevy
Duramax Forum Moderator
Points: 6,712, Level: 35
Points: 6,712, Level: 35 Points: 6,712, Level: 35 Points: 6,712, Level: 35
Activity: 100%
BigRedChevy's Avatar
If these trucks have no vacuum then how is it getting to the heaters to blow up or cause damage to the internal parts? Not trying to be smart, but either it will suck it in or it wont.
BTW it will work.
KYLE
05 Chevy LLY Crew Cab LT Dually 4x4, Crank it up Diesel Tie rod sleeves and centerlink, BD Diesel Remote Fuel Filter, EGR Blocked, TTS Dual Lift Pumps, FPRV Shim, Bullydog Outlook Monitor, AFE Stage 2 CAI, BD Diesel Manifold, Diamond Eye Turbo Direct Pipe, Diamond Eye 5" exhaust straight piped, Level Kit, Suncoast Stage IV w/ 1056 Torque Converter and Allison Deep pan
Old 06-27-2008, 10:47 PM   eBay Motors   #6 (permalink)
Tow Master
Super Man Moderator
Activity: 99%
Tow Master's Avatar
Yup ther is definatly vacum in the intake and boost lines. If there wasnt the truck wouldnt get any air!
It will damage your vehicle to use a ton of starting fluid. But, if there is a small leak then a small amount of fluid will go in and the truck will be fine.
Jason
Old 06-27-2008, 10:57 PM   eBay Motors   #7 (permalink)
daddysLBZ
AIN'T SKEERED!!
Activity: 100%
daddysLBZ's Avatar
Talking
noob the noob!!!
Old 06-28-2008, 04:53 AM   eBay Motors   #8 (permalink)
Johnasara
Points: 4,249, Level: 27
Points: 4,249, Level: 27 Points: 4,249, Level: 27 Points: 4,249, Level: 27
Activity: 60%
Activity: 60% Activity: 60% Activity: 60%
Johnasara's Avatar
I do not know about the older models but mine hisses when it is idleing because of the VVT you can hear it change. I noticed it more Yesterday when I was installing an EGT probe.
06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR
WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST. QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE
